Philips 86BDL4150D 86" 3840x2160 12ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: FFC7WS00 Mfr#: 86BDL4150D/00
Impress with a large diameter display. Designed to run Android Apps, the Philips D-Line is the high-performance powerhouse for corporate, educational and similar environments that need to go bigger.
  • Powered by Android
    With Android OS integrated into the display, you can work with the most developed OS on the planet and save your own app directly into the display. Or, choose from the large library of Android apps and play content from there. With the built-in scheduler, you can daypart your apps and content based on your customer and time of day and with the auto orientation feature, showing content in portrait or landscape is as simple as turning the display.
  • 4K ultra HD resolution
    See your Signage Solutions like never before thanks to four times the resolution of a conventional Full HD display. It provides and image so refined, so lifelike, it's a window to a new world.
  • Mini PCI slot
    With a mini PCI express slot built in, you can easily extend display connectivity to include 4G LTE modules. This is also a great way to enhance machine to machine communication. Result: a world of configuration possibilities, such as adding product features or expanding signalhandling capabilities.
  • Internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
  • Proof of play
    Content is king, and with the automatic screenshot feature, you can make sure that your content is up and running at all times. Screenshots are taken throughout the day, which are then stored in the FTP server. From there, the screenshots can be viewed no matter when or where you are.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you're ready for instant protection.
  • FailOver for meeting rooms
    Using FailOver, simplify your presentations and videoconferencing. When a meeting or conference room is not in use, background content can run from whatever input source you choose. When the meeting starts and you need to share a presentation or your screen, simply connect your computer and the display automatically switches inputs and shows what's on your screen, with no need to manually switch inputs.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • CMND & Create
    Design and create compelling content with CMND & Create, a powerful authoring tool. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content.
Philips 86BDL4150D D-Line - 86" Class (85.6" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/337947
Diagonal Class
86"
Diagonal Size
85.6"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480/60p, 720/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 1080/30i, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright
Speaker System
2 speakers
Storage Drive Capacity
64 GB
Storage Capacity
64 GB
Supported Memory Cards
microSD
USB
Remote control, batteries
Voltage
Energy Class
Class G
Power Consumption (On mode)
234.3 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
350 kWh
192.79 cm x 8.59 cm x 109.89 cm
63.8 kg
3-year warranty
Energy Class
Class G
234.3 W
234.3 kWh/1000h
350 kWh
Diagonal Class
86"
Diagonal Size
85.6"
Commercial Use
Series
D-Line
Operating System
Android OS 7.1.2
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode
Dimensions
Without stand
192.79 cm
8.59 cm
109.89 cm
63.8 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
12 ms
Display Menu Language
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Commercial Features
CMND management
3D MA deinterlacing, Smart Insert, Intel OPS compatible, picture in picture (no tuner), Signal Failover
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, TS, DAT, WebM, MPG, MPEG
Supported Audio Formats
MP3, WMA, AAC, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
microSD
USB Port
Configuration
ARM Cortex-A73 Dual-Core + ARM Cortex-A53 Dual-Core - 4 GB - 64 GB - Mali T864
64 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 3 x HDMI input , DVI-D input , VGA input , DisplayPort output , Audio line-out , Audio line-in , RS-232 input , RS-232 output , LAN , USB , USB , USB
Batteries
HDMI cable , IR extender cable - 1.8 m , Serial cable
FCC Class B certified, UL, C-Tick, BSMI, GOST, cUL, CB, RoHS
Power supply
Input Voltage
0.5 Watt
Smart power
Limited warranty - 3 years
Weight (Shipping)
93.9 kg
20 - 80% (non-condensing)
