Deliver startlingly clear images in a more eco-friendly way with the Q-Line display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
CMND
A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND. -
CMND & Control
With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier. -
CMND & Create
Design and create compelling content with CMND & Create, a powerful authoring tool With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content. -
SmartPlayer
Turn your USB into a true cost effective digital Signage device. Simply save your content video, audio, pictures on your USB and plug into your display. Create your playlist and Schedule your content via the on screen menu and enjoy your own created playlists anytime anywhere.
- Philips 86BDL3050Q Q-Line - 86" Class (85.6" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/337946
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Yes - digital signage
- Platform
- Android
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 480/60p, 720/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 1080/30i, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
- Max Number of Screens
- 150
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- HTML5 support, CMND management
- Picture Enhancements
- Colour temperature adjustment, Noise Reduction, dynamic contrast enhancement, Pixel Shift, Colour Enhancement, 3D Digital Comb Filter
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- Supported Memory Cards
- microSD
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- Power Consumption (On mode)
- 301.8 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 441 kWh
- Dimensions (WxDxH) - without stand
- 192.79 cm x 8.59 cm x 109.89 cm
- 63.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 301.8 W
- Power Consumption SDR (On mode)
- 301.8 kWh/1000h
- 441 kWh
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Series
- Q-Line
- Platform
- Android
- Operating System
- Android OS 5.1
- Video Processor
- Quad-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- Modes
- Landscape mode
- Dimensions
- Without stand
- 192.79 cm
- 8.59 cm
- 109.89 cm
- 63.8 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 410 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 8 ms
- Display Menu Language
- Multilingual
- Backlight Life
- 50,000 hour(s)
- 3D MA deinterlacing, Smart Insert
Video Wall
- 150
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800
Media Player
- Supported Video Formats
- MPEG-4, WMV, ASF, AVI, MKV, MOV, VOB, FLV, TS, DAT, TRP, WebM, MPG, MPEG
- Supported Audio Formats
- MP3, WMA, AAC, M4A
- Supported Pictures Formats
- BMP, JPG, PNG, JPEG
- microSD
- USB Port
- USB Ports Qty
- 2
- Configuration
- 8 GB
- 8 GB
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , DisplayPort input , 4 x HDMI , Audio line-in , Audio line-out , Serial input , Serial output , Infrared input , Infrared output , LAN , Audio line-in , 2 x USB 2.0
- Batteries
- Cables Included
- HDMI cable , IR extender cable - 1.8 m , Serial cable
- FCC Class B certified, UL, BSMI, cUL, CB, CCC, PSB, EMF, EAC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
