Experience your content like never before thanks to four times the resolution of a conventional display. This ultra large 75" display offers 3840 x 2160 pixels so refined, so lifelike, it's a window to an amazing world.
High brightness - 3000 nit
Enjoy an excellent visual experience even in areas illuminated by direct sunlight thanks to the 3000 nit panel. The high brightness offers a wide array of great implementation possibilities especially in locations that have high ambient light levels, delivering crystal clear images for all locations where ambient brightness is an issue. -
4K Ultra HD resolution
See your signage solutions like never before thanks to four times the resolution of a conventional Full HD display. 3840 x 2160 pixels provide and image so refined, so lifelike, it's a window to a different world. -
QuadViewer
Be more flexible with your screen real estate. With the ability to play content from up to four separate inputs, all on one screen. QuadViewer is ideal for control rooms, corporate environments, and meeting rooms. -
CMND
A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND. -
FailOver
Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you're ready for instant protection. -
SmartPower
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
- Philips 75BDL3003H H-Line - 75" Class (74.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- CMND management
- Picture Enhancements
- Motion Compensation, dynamic contrast enhancement, Pixel Shift
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries, carrying handle
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 200 Watt
- Power Consumption (On mode)
- 382 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 558 kWh
- 168.12 cm x 14.24 cm x 95.66 cm
- 54.1 kg
- 3-year warranty
- Product Type
- Energy Class
- Class C
- 200 Watt
- 382 W
- 558 kWh
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Commercial Use
- Series
- H-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Landscape mode
- 168.12 cm
- 14.24 cm
- 95.66 cm
- 54.1 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 3000 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- CMND management
- Operation Hours / Days
- 24 / 7
- 3D MA deinterlacing, Smart Insert, Intel OPS compatible, picture in picture (no tuner)
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- Supported Video Formats
- MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
- Supported Audio Formats
- MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
- Supported Pictures Formats
- BMP, JPG, GIF, JPEG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- 3 x HDMI input , VGA input , DVI-D input , Component video input , DisplayPort input , Audio line-in , DisplayPort output , Audio line-in , Audio line-out , Composite video input , Speakers output , SPDIF output , Serial , LAN , Remote control , USB
- Batteries, carrying handle
- FCC Class A certified, UL, C-Tick, GOST, cUL, CCC, RoHS
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80%
