Impress with a large diameter display. The Philips D-Line is a high-performance powerhouse for corporate, educational and similar environments that need to go bigger.
Ultra HD resolution
See your signage solutions like never before thanks to four times the resolution of a conventional Full HD display. More pixels provide and image so refined, so lifelike, it's a window to the world. -
Smart power
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs. -
Content protection
Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, D-Line provides content protection with an incredible technology that plays back-up content on screen in the event of a media player failure.
- Philips 65BDL4150D D-Line - 65" Class (64.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/402000
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Max Number of Screens
- 150
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- CMND management, Open Pluggable Standard (OPS) support
- Picture Enhancements
- Pixel Shift, 3D Digital Comb Filter
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 32 GB
- Storage Capacity
- 32 GB
- USB
- 3 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 267 Watt
- Power Consumption (On mode)
- 181 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 262 kWh
- Dimensions (WxDxH) - without stand
- 145.78 cm x 6.69 cm x 83.56 cm
- 36.5 kg
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 267 Watt
- 181 W
- Power Consumption SDR (On mode)
- 181 kWh/1000h
- 262 kWh
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Series
- D-Line
- Operating System
- Android OS 7.1.2
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 145.78 cm
- 6.69 cm
- 83.56 cm
- 36.5 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1100:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 8 ms
- Display Menu Language
- Multilingual
- Backlight Life
- 50,000 hour(s)
- Operation Hours / Days
- 24 / 7
- 3D MA deinterlacing, Smart Insert, picture in picture (no tuner)
Video Wall
- 150
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1440 x 1050, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 640 x 350, 720 x 400, 848 x 480, 1152 x 900, 1360 x 768, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1400 x 1050, 1600 x 900, 3840 x 2160, 4096 x 2160, 960 x 720
Media Player
- Supported Video Formats
- MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, TS, DAT, WebM, MPEG
- Supported Audio Formats
- MP3, WMA, AAC, M4A
- Supported Pictures Formats
- BMP, JPG, PNG, JPEG
- USB Port
- USB Ports Qty
- 3
- Configuration
- 32 GB
- 32 GB
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DisplayPort input , 4 x HDMI input , DVI-D input , VGA input , DisplayPort output , SPDIF output , Audio line-in , Audio line-out , USB , USB 2.0 , USB 3.0 , Remote control , Serial input , Serial output , Infrared input , Infrared output
- Batteries
- Cables Included
- Serial cable , VGA cable
- FCC Class B certified, CB
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0.3 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
Philips 65BDL4150D 65" 3840x2160 8ms VGA DVI HDMI DisplayPort LED Large Format Display
