Philips 65BDL4050D 65" 1920x1080 12ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: FFBSWS00 Mfr#: 65BDL4050D/00
TV Tuner Presence: No
Video Interface: HDMI
  • USB
  • 1080p (Full HD)
Hurry, only 3 left in stock!
£1,280.09 ex VAT
£1,536.10 inc VAT
Amaze your guests with a smarter, faster, signage display. With integrated Wi-Fi and capable of running Android apps, it's the next evolution in signage solutions
Philips Signage Solutions D-Line 65BDL4050D 65" Class (65.5" viewable) LED display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
65.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number Of Screens
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, DisplayPort, USB
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Low Bright
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Supported Memory Cards
microSD
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A+
103 Watt
Power Consumption (On mode)
108 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
151 kWh
145.2 cm x 6.35 cm x 83.31 cm
29.8 kg
3-year warranty
Energy Class
Class A+
103 Watt
108 W
151 kWh
Diagonal Class
65"
Diagonal Size
65.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
225
Dimensions
Without stand
145.2 cm
6.35 cm
83.31 cm
29.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
3D MA deinterlacing, Motion Compensation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 100 mm, 400 x 400 mm, 100 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
microSD
USB Port
PC Configuration
ARM Cortex-A9 Quad-Core / 1.8GHz/ 2 GB DDR3 / Mali-400 Quad-Core / 533 MHz
16 GB
Operating System
Android OS
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , USB , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Network , Serial input , Infrared input , USB , USB , Serial output , Infrared output
Batteries
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Brand: Philips
Price Range Ex VAT: 1000 - 1500
