Philips 65BDL3050Q 65" 3840x2160 8ms VGA HDMI DisplayPort LED Large Format Display
Quicklinx: FFBQWS00 Mfr#: 65BDL3050Q/00
Video Interface: HDMI
TV Tuner Presence: No
£1,083.93 ex VAT
£1,300.71 inc VAT
Deliver startlingly clear images in a more eco-friendly way with the Q-Line display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • Take control of your displays
    A robust display management platform, CMND puts the power back into your hands. Update and manage content or control your settings.
  • Create and update content
    Design and create compelling content. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content. Available in portrait and landscape mode.
  • Connect and control your content via the cloud
    Connect and control your content via the cloud with the integrated browser. Design your signage content online and connect it with a display or with your complete network.
  • Ultra HD resolution
    See your signage solutions like never before thanks to four times the resolution of a conventional Full HD display. Ultra HD provides an image so refined, so lifelike, it's a window to a different world.
Philips 65BDL3050Q Q-Line - 65" Class (64.5" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/395524
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - digital signage
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
Max Number of Screens
150
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
VGA (HD-15), DisplayPort
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, CMND management
Picture Enhancements
Colour temperature adjustment, Noise Reduction, dynamic contrast enhancement, Pixel Shift, Colour Enhancement, 3D Digital Comb Filter
Speaker System
2 speakers
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
microSD
USB
2 ports
Remote control, batteries
Voltage
Energy Class
Class G
110 Watt
Power Consumption (On mode)
186 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
272 kWh
145.87 cm x 8.16 cm x 83.47 cm
24.8 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
110 Watt
186 W
186 kWh/1000h
272 kWh
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Series
Q-Line
Platform
Android
Operating System
Android OS 5.1
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
Modes
Landscape mode, Smart Picture Mode
Dimensions
Without stand
145.87 cm
8.16 cm
83.47 cm
24.8 kg
Display
LCD Display Technology
AMVA
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
Commercial Features
3D MA deinterlacing, Smart Insert
Video Wall
150
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, MOV, VOB, FLV, TS, DAT, TRP, WebM, MPG, MPEG
Supported Audio Formats
MP3, WMA, AAC, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
microSD
USB Port
USB Ports Qty
2
Configuration
8 GB
8 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , DisplayPort input , 4 x HDMI , 2 x USB 2.0 , Audio line-in , Audio line-out , Serial input , Serial output , Infrared input , Infrared output , LAN , Audio line-in
Batteries
HDMI cable , IR extender cable - 1.8 m , Serial cable
FCC Class B certified, UL, BSMI, cUL, CB, CCC, PSB, EMF, EAC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Brand: Philips
Price Range Ex VAT: £1000 - £1500
