Philips 55BDL5055P 55" 1920x1080 8ms DVI HDMI DisplayPort LED Large Format Display
Quicklinx: FFBJWS00 Mfr#: 55BDL5055P/00
  • 1080p
  • USB
Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache, when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring, that your media stays up, even if the network goes down.
  • Keep your content up and running with FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with an advanced technology, that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you're ready for instant protection.
  • CMND - take control of your displays
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND and Create or control your settings with CMND and Control. It's all possible with CMND.
  • Manage settings of multiple displays with CMND and Control
    With CMND and Control, easily manage multiple displays in a central location. With real time display monitoring, setting and updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • Create and update content with CMND and Create
    Design and create compelling content with CMND and Create, a powerful authoring tool. With a drag-and-drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content.
  • Connect and control your content via the cloud
    Connect and control your content via the cloud with the integrated HTML5 browser. Using the browser, design your content online and connect a single display, or your complete network. Show content in both landscape and portrait mode, with Full HD resolution. Streaming content can also be shown in a PIP (picture-in-picture) window. Simply connect the display to the Internet, using Wi-Fi or with an RJ-45 cable, and enjoy your own created playlists.
  • SmartPower for energy saving
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
Philips Signage Solutions P-Line 55BDL5055P 55" Class (54.64" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/337943
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort, USB
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
Supported Memory Cards
microSD
USB
Remote control, batteries
Voltage
Energy Class
Class G
110 watt
Power Consumption (On mode)
123.3 W
Power Consumption Stand by
0.5 watt
Energy Consumption per Year
181 kWh
122.86 cm x 5.68 cm x 69.94 cm
25.2 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
110 watt
123.3 W
123.3 kWh/1000h
181 kWh
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Operating System
Android OS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Dimensions
Without stand
122.86 cm
5.68 cm
69.94 cm
25.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
Backlight Life
60,000 hour(s)
Commercial Features
CMND management
Certified for 24/7 Continuous Operation
Video Wall
225
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 3840 x 2160
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG, PDF
microSD
USB Port
USB Ports Qty
1
Configuration
ARM Cortex-A53 Octa-Core ( 1.5 GHz ) - 2 GB DDR3 - 16 GB - PowerVR SGX6110
16 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x main channel speaker - 10 watt
Network & Internet Multimedia
Wi-Fi, LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
One Wire
Connector Type
DisplayPort input , 2 x HDMI , DVI-D input , USB , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Audio line-out , LAN , Serial input , Serial output , Infrared input , Infrared output , mPCIe slot
Batteries
Serial cable
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power adapter
Input Voltage
0.5 watt
Power Consumption (Off Mode)
0.5 watt
Smart power
Limited warranty - 3 years
20 - 80%
