Philips 55BDL4051T 55" 1920x1080 12ms VGA DVI HDMI DisplayPort LED Display
Quicklinx: FFBHWS00 Mfr#: 55BDL4051T/00
Video Interface: HDMI
TV Tuner Presence: No
  • 1080p
£1,487.65 ex VAT
£1,785.18 inc VAT
Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by enhanced reliability and functionality.
  • Plug and Play multi-touch
    A high level of interactivity is now available thanks to integrated touch technology. More flexibility and optimum simultaneous touch performance coupled with great operability opportunities to give you the ultimate in user interaction. The multi-touch displays are enabled with automatic touch recognition. The USB connector is HID compliant, providing true Plug-and-Play operation.
  • Anti-glare glass
    With this integrated touch display, the antiglare glass with low optical parallax allows for immersive touch experience. With little to no glare and low reflection on the display, images are crystal clear with pure color and great clarity.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and your ready for instant protection.
  • Internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
  • PCI slot
    With an integrated PCI slot, you can connect an extra Wi-Fi/Bluetooth or 4G LTE module, allowing for even greater communication with the display. Machine to machine communication is also enhanced, with numerous configurations available for customers to use, such as the ability to expand product features or signal-handling capability.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
Philips Signage Solutions 55BDL4051T 55" Class (54.64" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/337839
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Low Bright
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
Supported Memory Cards
microSD
USB
Remote control, batteries, carrying handle
Voltage
Energy Class
Class F
76 Watt
Power Consumption (On mode)
76.5 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
112 kWh
127.1 cm x 9.14 cm x 74.18 cm
31 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class F
76 Watt
76.5 W
76.5 kWh/1000h
112 kWh
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Combined With
Touchscreen
Operating System
Android OS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
Protection
Tempered glass protection
Dimensions
Without stand
127.1 cm
9.14 cm
74.18 cm
31 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Touchpoints Qty
10
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Commercial Features
CMND management
Certified for 24/7 Continuous Operation, 3D MA deinterlacing, infrared multitouch technology, Motion Compensation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
microSD
USB Port
Configuration
16 GB
16 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , USB , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , LAN , Serial input , Remote control input , USB , USB , Serial output , Remote control output
Batteries, carrying handle
Serial cable , USB cable
Plug and Play, FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Brand: Philips
Price Range Ex VAT: £1000 - £1500
