Philips 55BDL3005X 55" 1920x1080 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: FRYNWS00 Mfr#: 55BDL3005X/00
  • 1080p
Command attention with a Philips X-Line Professional Videowall Display. Crisp contrast and narrow bezels enable clear, distraction-free imaging. Whether you're running an airport or hosting a conference.
  • Tiling mode
    Connect two or more Philips professional displays to create a tiled videowall - without the need for external devices. A single player takes care of content, whether you have four screens or 40. 4K content is fully supported, and if you're showing that content on four screens you get the best possible dot-by-dot resolution.
  • CMND & Control
    Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • OPS slot
    The OPS slot contains all the connections you need to run your slot-in solution, including a power supply.
Philips Signage Solutions Video Wall Display 55BDL3005X X-Line Professional Videowall - 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright
Speaker System
2 speakers
Remote control, batteries, thumb screw, edge alignment pins, edge alignment plates
Voltage
AC 120/230 V
Power Consumption (On mode)
110 W
Power Consumption Stand by
0.5 Watt
Dimensions (WxDxH) - panel
121.34 cm x 10.765 cm x 68.42 cm
26.5 kg
3-year warranty
110 W
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode, Tiling Mode (10 x 10)
Dimensions
Panel
121.34 cm
10.765 cm
68.42 cm
26.5 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
60,000 hour(s)
3D MA deinterlacing, 3:2 pull down compensation, 2:2 pull down compensation
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 3840 x 2160
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
Component video input , Composite video input , DVI-D input , 2 x HDMI input , VGA input , DisplayPort input , DisplayPort output , DVI-I output , Audio line-in , Audio line-out , Extension speaker output , IR emitter , LAN , RS-232C
Batteries, thumb screw, edge alignment pins, edge alignment plates
IR cable , IR sensor cable - 1.8 m , RS-232 daisy chain cable , RS-232 cable , DVI cable
FCC Class B certified, UL, GOST, cUL, CB
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
