Impress your audience with the most impactful video wall. With 1.8 mm ultra narrow bezel and stunning picture quality, you are sure to create the most memorable visual experience.
Full HD LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
IPS Display Technology
Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menu board applications which demand color accuracy and consistent brightness at all times. -
High brightness
Enjoy a clearer image in areas with greater ambient brightness thanks to the 700 nit panel. Your audience can enjoy better image quality in locations that are away from direct sunlight yet still brighter than average, optimizing the viewing experience. -
Ultra Narrow Bezel
The next generation of video wall displays is designed with industry narrowest bezels and advanced alignment solutions. Fully exploit your impactful signage content with ultra narrow bezel displays, and make sure your message does not get lost by thick bezels. With the ultra narrow bezels you can create seamless video wall configurations of virtually any size. -
Advanced Color Calibration
The Advanced Color Calibration kit controls the luminance of the backlight, standardizes the gamma curve and calibrates the grayscale of your display network. Whether you have an impressive video wall, a catchy mosaic layout, a menu board installation or a control room each display can be adjusted to the same color values. With this optional kit you ensure consistent color performance over all displays in your network. -
FailOver
Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and your ready for instant protection. -
SmartPower
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs. -
OPS Insert
Turn your display into an all-in-one digital signage solution and create a display network which is connected, intelligent and secure. Open Pluggable Specification (OPS) is an industry standard slot into which you can add an OPS standardized media player. This cable free solution gives you the ability to install, use or maintain your hardware whenever you need. -
Designed for 24/7 operation
Because business never sleeps, signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability. -
CMND & Control
With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
- Philips Signage Solutions 55BDL1007X X-Line - 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/337836
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Motion Compensation, dynamic contrast enhancement, Pixel Shift, Advanced Colour Calibration
- Speaker System
- 2 speakers
- Included Accessories
- Batteries, carrying handle, edge alignment pins, edge alignment plates
- Energy Class
- Class G
- 168 Watt
- Power Consumption (On mode)
- 135 W
- Power Consumption Stand by
- 0.65 Watt
- Energy Consumption per Year
- 191 kWh
- Dimensions (WxDxH) - without stand
- 121.14 cm x 9.85 cm x 68.22 cm
- 24.35 kg
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 168 Watt
- 135 W
- Power Consumption SDR (On mode)
- 135 kWh/1000h
- 191 kWh
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Series
- X-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- Design
- Ultra Narrow Bezel Concept
- Dimensions
- Without stand
- 121.14 cm
- 9.85 cm
- 68.22 cm
- 24.35 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- Operation Hours / Days
- 24 / 7
- 3D MA deinterlacing, Smart Insert, Intel OPS compatible
Video Wall
- 100
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- Component video input , Composite video input , 2 x HDMI , VGA input , DisplayPort input , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Infrared (IrDA) , Remote control , Remote control
- Cables Included
- Serial cable
- FCC Class B certified, UL, GOST, cUL, CB
- 0.65 Watt
- 0.65 Watt
- Energy save, smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
