Philips 50BDL3050Q 50" 3840x2160 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: FFB4WS00 Mfr#: 50BDL3050Q/00
Video Interface: HDMI
TV Tuner Presence: No
£629.34 ex VAT
£755.20 inc VAT
Deliver startlingly clear images in a more eco-friendly way with the Q-Line display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • 4K Ultra HD resolution
    See your Signage Solutions like never before thanks to four times the resolution of a conventional Full HD display. 3840 x 2160 pixels provide and image so refined, so lifelike, it's a window to a new world.
  • Powered by Android
    With Android OS integrated into the display, you can work with the most developed OS on the planet and save your own app directly into the display. Or, choose from the large library of Android apps and play content from there. With the built-in scheduler, you can daypart your apps and content based on your customer and time of day and with the auto orientation feature, showing content in portrait or landscape is as simple as turning the display.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
  • CMND & Create
    Design and create compelling content with CMND & Create, a powerful authoring tool. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content. Available in portrait and landscape mode.
  • SmartBrowser
    Connect and control your content via the cloud with the integrated HTML5 browser. Design your signage content online and connect it with a display or with your complete network. Simply plug in a RJ45 internet cable for network connection, connect the display with the dedicated URL-address and you are ready to play your cloud based content.
  • SmartPlayer
    Turn your USB into a true cost effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on screen menu, and enjoy your own created playlists anytime, anywhere.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
Philips 50BDL3050Q Q-Line - 50" Class (49.5" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
50"
Diagonal Size
49.5"
Commercial Use
Yes - digital signage
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480/60p, 720/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 1080/30i, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Colour temperature adjustment, Noise Reduction, dynamic contrast enhancement, Colour Enhancement
Speaker System
2 speakers
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
USB
2 ports
Remote control, batteries
Voltage
AC 120/230 V
Energy Class
Class G
128 Watt
Power Consumption (On mode)
128 W
Power Consumption Stand by
0.5 Watt
112.36 cm x 6.78 cm x 64.67 cm
12.6 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
128 Watt
128 W
128 kWh/1000h
Diagonal Class
50"
Diagonal Size
49.5"
Commercial Use
Series
Q-Line
Platform
Android
Operating System
Android OS 5.0.1
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI
Modes
Smart Picture Mode
Dimensions
Without stand
112.36 cm
6.78 cm
64.67 cm
12.6 kg
Display
LCD Display Technology
AMVA
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Multilingual
Commercial Features
CMND management
Operation Hours / Days
18 / 7
3D MA deinterlacing
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800, 3840 x 2160
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, MOV, VOB, FLV, TS, DAT, TRP, WebM, MPG, MPEG
Supported Audio Formats
MP3, WAV, AAC, MP4
Supported Pictures Formats
BMP, JPG, PNG, JPEG
USB Port
USB Ports Qty
2
Configuration
8 GB
8 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-D input , 2 x HDMI , 2 x USB , Audio line-in , Audio line-out , RS-232C , IR emitter , LAN
Batteries
Serial cable , IR extender cable - 1.8 m
FCC Class B certified, UL, BSMI, cUL, CB, CCC, PSB, EMF, CECP, EAC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Brand: Philips
Price Range Ex VAT: £500 - £750
