Command attention with a Philips X-Line Professional Videowall Display. Crisp contrast and narrow bezels enable clear, distraction-free imaging. Whether you're running an airport or hosting a conference.
Tiling mode
Connect two or more Philips professional displays to create a tiled videowall - without the need for external devices. A single player takes care of content, whether you have four screens or 40. 4K content is fully supported, and if you're showing that content on four screens you get the best possible dot-by-dot resolution. -
CMND & Control
Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100. -
OPS slot
Integrate a full-power PC or Android-powered CRD50 module directly into your Philips professional display. The OPS slot contains all the connections you need to run your slot-in solution, including a power supply.
- Philips Signage Solutions Video Wall Display 49BDL3005X 49" Class (48.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/337826
- Diagonal Class
- 49"
- Diagonal Size
- 48.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Motion Compensation, dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright, Billion Colors
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, batteries, thumb screw, edge alignment pins, edge alignment plates
- Energy Class
- Class G
- 110 Watt
- Power Consumption (On mode)
- 76 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - panel
- 107.76 cm x 10.38 cm x 60.78 cm
- 21.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 110 Watt
- 76 W
- Power Consumption SDR (On mode)
- 76 kWh/1000h
- Diagonal Class
- 49"
- Diagonal Size
- 48.5"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- Dimensions
- Panel
- 107.76 cm
- 10.38 cm
- 60.78 cm
- 21.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- 3D MA deinterlacing, 3:2 pull down compensation, 2:2 pull down compensation
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 3840 x 2160
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Carrying handles
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- DVI-D input , 2 x HDMI , VGA input , DisplayPort input , HD component input , Composite video/audio input , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Extension speaker output , IR emitter , LAN , RS-232C
- Batteries, thumb screw, edge alignment pins, edge alignment plates
- Cables Included
- IR transmitter cable , IR extender cable - 1.8 m , RS-232 daisy chain cable , RS-232 cable , DVI cable
- FCC Class B certified, UL, GOST, cUL, CB
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
