Philips 49BDL3005X 49" LED Video Wall Display
Quicklinx: FF9WWS00 Mfr#: 49BDL3005X/00
Video Interface: HDMI, Component, Composite
TV Tuner Presence: No
  • 1080p
£1,119.80 ex VAT
£1,343.76 inc VAT
Command attention with a Philips X-Line Professional Videowall Display. Crisp contrast and narrow bezels enable clear, distraction-free imaging. Whether you're running an airport or hosting a conference.
  • Tiling mode
    Connect two or more Philips professional displays to create a tiled videowall - without the need for external devices. A single player takes care of content, whether you have four screens or 40. 4K content is fully supported, and if you're showing that content on four screens you get the best possible dot-by-dot resolution.
  • CMND & Control
    Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • OPS slot
    Integrate a full-power PC or Android-powered CRD50 module directly into your Philips professional display. The OPS slot contains all the connections you need to run your slot-in solution, including a power supply.
Philips Signage Solutions Video Wall Display 49BDL3005X 49" Class (48.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/337826
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright, Billion Colors
Speaker System
2 speakers
Remote control, batteries, thumb screw, edge alignment pins, edge alignment plates
Energy Class
Class G
110 Watt
Power Consumption (On mode)
76 W
Power Consumption Stand by
0.5 Watt
Dimensions (WxDxH) - panel
107.76 cm x 10.38 cm x 60.78 cm
21.6 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
110 Watt
76 W
76 kWh/1000h
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Dimensions
Panel
107.76 cm
10.38 cm
60.78 cm
21.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Direct-lit LED
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
3D MA deinterlacing, 3:2 pull down compensation, 2:2 pull down compensation
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 3840 x 2160
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
Carrying handles
Speakers
2 x speaker - 10 Watt
Connector Type
DVI-D input , 2 x HDMI , VGA input , DisplayPort input , HD component input , Composite video/audio input , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Extension speaker output , IR emitter , LAN , RS-232C
Batteries, thumb screw, edge alignment pins, edge alignment plates
IR transmitter cable , IR extender cable - 1.8 m , RS-232 daisy chain cable , RS-232 cable , DVI cable
FCC Class B certified, UL, GOST, cUL, CB
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Video Interface: Component
Video Interface: Composite
Brand: Philips
Price Range Ex VAT: £1000 - £1500
