Surprise and delight with a professional IPTV. Cost-effective central management, quick installation, and a customizable UI make this a flexible solution. Philips world-renowned picture quality always engages.
UI branding
Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo and colors to the search bar to increase the visibility of your brand. -
Built-in pay-to-view solution
Offer pay-to-view content in any situation-from a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card. -
IPTV: provide channels over IP
Provide channels over IP. Install your own user interface (UI), which can be stored on a central server and sent to the TV over IP. Once the UI is on the TV it can also be stored locally. You'll benefit from flexibility and rapid installation whether you're personalizing your Philips Pro System TVs or centralizing system management. -
CMND & Control
Run your display network over a local (LAN or RF) connection. CMND & Control allows you to perform vital functions like controlling inputs, updating software, and monitoring display status. Whether you're in charge of one TV or more. -
CMND & Create
Take control of your content with CMND & Create. A drag-and-drop interface makes it simple to publish your own content-whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure your stills, text, and video will be up and running in no time.
- Philips 43HFL4014 Professional PrimeSuite - 43" LED-backlit LCD TV - for hotel / hospitality
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Commercial Use
- Yes - hotel / hospitality
- Black
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL
- Internet Streaming Services
- YouTube, HbbTV
- Commercial Features
- VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, IPTV, CMND management, Playready Smoothstreaming, Joystick Control Lock, menu lock
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- Incredible Surround
- USB
- 2 ports
- Included Accessories
- Philips 22AV1904A/12 remote control, batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class F
- Power Consumption (On mode)
- 44 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 66 kWh
- Dimensions (WxDxH) - without stand
- 97 cm x 8.2 cm x 54.25 cm
- 7.2 kg
