Philips 43BDL3010Q 43" 1920x1080 6.5ms VGA DVI HDMI USB LED Large Format Display
Quicklinx: FRYKWS00 Mfr#: 43BDL3010Q/00
  • 1080p
Easily schedule content to play from USB. Your Philips professional display will wake from standby to play the content you want, and then return to standby once playback is done.
  • Operate, monitor, maintain
    Run your display network over a local (LAN) connection. CMND & control allows you to perform vital functions like controlling inputs and monitoring display status.
  • Ensure your display never goes blank
    From waiting room to meeting room, never show a blank screen. Your Philips display can switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
Philips 43BDL3010Q Q-Line - 43" Class (42.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/394482
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 1080/50i, 720/50p, 576/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI
VA
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Clinical D-image
Picture Enhancements
Dynamic contrast enhancement
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
Energy Class
Class G
110 Watt
Power Consumption (On mode)
80 W
Power Consumption Stand by
0.5 Watt
96.82 cm x 6.09 cm x 55.94 cm
8.8 kg
3-year warranty
Energy Class
Class G
110 Watt
80 W
80 kWh/1000h
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Series
Q-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI
Modes
Landscape mode
Dimensions
Without stand
96.82 cm
6.09 cm
55.94 cm
8.8 kg
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
3000:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
6.5 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Commercial Features
Clinical D-image
Operation Hours / Days
18 / 7
3D MA deinterlacing, DICOM support
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 720, 720 x 400, 1152 x 870, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
Motion-JPEG, H.264, MPEG
Supported Audio Formats
WMA, AAC, HE-AAC
Supported Pictures Formats
BMP, PNG, JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-I , 2 x HDMI , USB , Audio line-in , Audio line-out , Remote control , RS-232C , Infrared (IrDA)
Batteries
Serial cable , IR sensor cable - 1.8 m
FCC Class B certified, CB
Power supply
Input Voltage
0.5 Watt
Smart power, power on delay
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
