Philips 43" 4K UHD LED Android TV
Quicklinx: GXY3WS00 Mfr#: 43PUS7906/12
  • DVB-T
  • DVB-S
The action leaps from the screen with this Philips 4K Android TV. HDR content looks great, and Ambilight makes movies, shows, and games feel bigger and more immersive. Dolby Atmos gives you premium sound to match the brilliant picture.
  • 3-sided ambilight
    With Philips ambilight every moment feels closer. Intelligent LEDs around the edge of the TV respond to the on-screen action and emit an immersive glow that's simply captivating. Experience it once and wonder how you enjoyed TV without it.
  • Dolby Vision + Dolby Atmos
    Support for Dolby's premium sound and video formats means the HDR content you watch will look-and sound-glorious. You'll enjoy a picture that reflects the director's original intentions and experience spacious sound with real clarity and depth.
  • Simply smart, Android TV
    Your Philips Android TV gives you the content you want-when you want it. You can customize the home screen to display your favorite apps, making it simple to start streaming the movies and shows you love. Or pick up where you left off.
  • Supports all major HDR formats
    Your Philips 4K UHD TV is compatible with all major HDR formats, including Dolby Vision. Whether it's a must-watch series or the latest video game, shadows will be deeper. Bright surfaces will shine. Colors will be truer.
  • HDMI 2.1 VRR and low latency
    Your Philips TV boasts the latest HDMI 2.1 connectivity, and the TV automatically switches to a low latency setting when you start playing a game on your console. VRR is supported for smooth fast-action gameplay. Ambilight's gaming mode brings the thrill right into the room.
  • Slim, attractive design
    Looking for a TV that fits with your room? This 4K smart TV is dressed for the occasion! The virtually bezel-free screen goes with just about any interior scheme. While the slim feet make it seem as if the screen is floating above your TV unit or table.
Philips 43PUS7906 7900 Series - 43" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/441226
Diagonal Class
43"
Charcoal grey
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
3840/60p
HDR Format
HDR10, HDR10+, Dolby Vision, HLG10
Frame Rate & Enhancement Technology
Variable Refresh Rate (VRR)
Video Interface
HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
Netflix, YouTube, BBC iPlayer, HbbTV, Amazon Prime Video, Disney+
Picture Enhancements
Pixel Precise Ultra HD
Speaker System
2 speakers
Intelligent Assistant
Google Assistant, Alexa (not available for some languages and countries)
Storage Capacity
8 GB
USB
2 ports
Remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class G
Power Consumption (On mode)
65 W
Power Consumption Stand by
0.3 Watt
96.28 cm x 7.81 cm x 55.82 cm
8.5 kg
Energy Class
Class G
Energy Class (HDR)
Class G
65 W
65 kWh/1000h
Power Consumption HDR (On mode)
63 kWh/1000h
Diagonal Class
43"
Series
7900 Series
Platform
Android TV
Operating System
Android TV 10
HDR Capable
HDR Format
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
Modes
Game mode, Eco mode, lounge mode
Ambilight
Ambilight Type
Ambilight 3-sided
Dimensions
Without stand
96.28 cm
7.81 cm
55.82 cm
8.5 kg
Enclosure Colour
Charcoal grey
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
One touch Play
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Charcoal grey
Stand Features
V-Shape
Flat Panel Mount Interface
100 x 200 mm
VESA Compatibility
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
MPEG Profiles and Levels
MPEG4/MPEG2/HEVC
Video Features
Input Video Formats
3840/60p
Supported Computer Resolutions
3840 x 2160
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
8-day EPG
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, AVI, MKV, AVC, H.264, HEVC, H.265, VP9, AV1
Supported Audio Formats
MP3, WMA, WAV, AAC, WMA Pro
Supported Pictures Formats
BMP, GIF, PNG, JPEG, HEIF
USB Port
USB Ports Qty
2
Configuration
Quad-Core 8 GB
Remote Control
Remote control
Battery Form Factor
AAA type
Battery Included Qty
2
Remote Control Pass Through
Audio System
Digital Audio Format
Dolby Atmos
Surround Mode
Equaliser
Yes (5-band)
Speaker System
2 speakers
Output Power / Total
20 Watt
Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control, Clear Dialogue, Dolby Bass Enhancement
Speakers
2 x speaker - 10 Watt
Driver Details
Speaker: 2 x full-range driver
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11n
Connect & Share
Screen Mirroring, SImplyShare
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
USB - side , HDMI - side , Headphones - side , Digital audio output (optical) - bottom , LAN - bottom , USB - bottom , 3 x HDMI - bottom
Internet of Things (IoT)
HDCP 2.3
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Auto On/Off
System standby
Dimensions & Weight Details
Panel without stand - 96.28 cm x 7.81 cm x 55.82 cm x 8.5 kg , Panel with stand - 96.28 cm x 23.57 cm x 58.52 cm x 8.7 kg , Stand - 77.93 cm x 23.57 cm x 2.7 cm
Width (Shipping)
107 cm
Depth (Shipping)
14 cm
Height (Shipping)
65 cm
Weight (Shipping)
11.3 kg
5 °C
35 °C
