The action leaps from the screen with this Philips 4K Android TV. HDR content looks great, and Ambilight makes movies, shows, and games feel bigger and more immersive. Dolby Atmos gives you premium sound to match the brilliant picture.
3-sided ambilight
With Philips ambilight every moment feels closer. Intelligent LEDs around the edge of the TV respond to the on-screen action and emit an immersive glow that's simply captivating. Experience it once and wonder how you enjoyed TV without it. -
Dolby Vision + Dolby Atmos
Support for Dolby's premium sound and video formats means the HDR content you watch will look-and sound-glorious. You'll enjoy a picture that reflects the director's original intentions and experience spacious sound with real clarity and depth. -
Simply smart, Android TV
Your Philips Android TV gives you the content you want-when you want it. You can customize the home screen to display your favorite apps, making it simple to start streaming the movies and shows you love. Or pick up where you left off. -
Supports all major HDR formats
Your Philips 4K UHD TV is compatible with all major HDR formats, including Dolby Vision. Whether it's a must-watch series or the latest video game, shadows will be deeper. Bright surfaces will shine. Colors will be truer. -
HDMI 2.1 VRR and low latency
Your Philips TV boasts the latest HDMI 2.1 connectivity, and the TV automatically switches to a low latency setting when you start playing a game on your console. VRR is supported for smooth fast-action gameplay. Ambilight's gaming mode brings the thrill right into the room. -
Slim, attractive design
Looking for a TV that fits with your room? This 4K smart TV is dressed for the occasion! The virtually bezel-free screen goes with just about any interior scheme. While the slim feet make it seem as if the screen is floating above your TV unit or table.
- Philips 43PUS7906 7900 Series - 43" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/441226
- Diagonal Class
- 43"
- Charcoal grey
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 3840/60p
- HDR Format
- HDR10, HDR10+, Dolby Vision, HLG10
- Frame Rate & Enhancement Technology
- Variable Refresh Rate (VRR)
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Internet Streaming Services
- Netflix, YouTube, BBC iPlayer, HbbTV, Amazon Prime Video, Disney+
- Picture Enhancements
- Pixel Precise Ultra HD
- Speaker System
- 2 speakers
- Intelligent Assistant
- Google Assistant, Alexa (not available for some languages and countries)
- Storage Capacity
- 8 GB
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class G
- Power Consumption (On mode)
- 65 W
- Power Consumption Stand by
- 0.3 Watt
- Dimensions (WxDxH) - without stand
- 96.28 cm x 7.81 cm x 55.82 cm
- 8.5 kg
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 65 W
- Power Consumption SDR (On mode)
- 65 kWh/1000h
- Power Consumption HDR (On mode)
- 63 kWh/1000h
- Diagonal Class
- 43"
- Series
- 7900 Series
- Platform
- Android TV
- Operating System
- Android TV 10
- HDR Capable
- HDR Format
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Modes
- Game mode, Eco mode, lounge mode
- Ambilight
- Ambilight Type
- Ambilight 3-sided
- Dimensions
- Without stand
- 96.28 cm
- 7.81 cm
- 55.82 cm
- 8.5 kg
- Enclosure Colour
- Charcoal grey
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- One touch Play
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Charcoal grey
- Stand Features
- V-Shape
- Flat Panel Mount Interface
- 100 x 200 mm
- VESA Compatibility
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- MPEG Profiles and Levels
- MPEG4/MPEG2/HEVC
Video Features
- 3840/60p
- Supported Computer Resolutions
- 3840 x 2160
- Teletext
- Teletext Memory
- 1000 pages
- Electronic Programme Guide
- 8-day EPG
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, AVI, MKV, AVC, H.264, HEVC, H.265, VP9, AV1
- Supported Audio Formats
- MP3, WMA, WAV, AAC, WMA Pro
- Supported Pictures Formats
- BMP, GIF, PNG, JPEG, HEIF
- USB Port
- USB Ports Qty
- 2
- Configuration
- Quad-Core 8 GB
Remote Control
- Remote control
- Battery Form Factor
- AAA type
- Battery Included Qty
- 2
- Remote Control Pass Through
Audio System
- Digital Audio Format
- Dolby Atmos
- Surround Mode
- Equaliser
- Yes (5-band)
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control, Clear Dialogue, Dolby Bass Enhancement
- Speakers
- 2 x speaker - 10 Watt
- Driver Details
- Speaker: 2 x full-range driver
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11n
- Connect & Share
- Screen Mirroring, SImplyShare
- Supported Consumer Electronics Control (CEC)
- EasyLink
- Connector Type
- USB - side , HDMI - side , Headphones - side , Digital audio output (optical) - bottom , LAN - bottom , USB - bottom , 3 x HDMI - bottom
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- HDCP 2.3
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
- System standby
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.28 cm x 7.81 cm x 55.82 cm x 8.5 kg , Panel with stand - 96.28 cm x 23.57 cm x 58.52 cm x 8.7 kg , Stand - 77.93 cm x 23.57 cm x 2.7 cm
- Width (Shipping)
- 107 cm
- Depth (Shipping)
- 14 cm
- Height (Shipping)
- 65 cm
- Weight (Shipping)
- 11.3 kg
- 5 °C
- 35 °C
