Like a piece of furniture Philips DesignLine Edge features a beautiful lifestyle design to fit your living room.
Pixel Precise HD and LED TV pictures together with Ambilight bring an immersive TV experience to your living room.
Intensify your viewing experience Ambilight Spectra 2-sided intensifies the viewing experience.
Easy 3D for a truly immersive 3D movie experience
Designed to fit your home
Full glass, lean back design to fit your living room
Action captured in stunning detail
Full HD TV with Pixel Precise HD for details in action
Brilliant LED images with incredible contrast
400 Hz Perfect Motion Rate (PMR) for superb motion sharpness
Enjoy the online world with Smart TV, A wealth of online apps, videos to rent and catch-up TV
With DLNA, enjoy photos, music and movies on your TV
Control the TV with your smart phone, tablet or keyboard
Find, schedule, record and pause TV
Integrated Wi-Fi to use Net TV apps and SimplyShare wireless
Add a new dimension to your viewing experience with Ambilight Spectra 2. This patented Philips technology enlarges the screen by projecting a glow of light from 2 sides of the back of the TV screen onto the surrounding wall. Ambilight automatically adjusts the colour and brightness of the light to match the TV picture. Thanks to the wall-adaptive function, the colour of the light is perfect, regardless of your wall colour
Easy 3D for a truly immersive 3D movie experience.
Easy 3D ensures you get long hours of comfort while watching 3D thanks to the flicker-free, low ghosting performance. The compatible 3D glasses are lightweight and do not require batteries. Enjoy 3D easily at home today!
Full HD TV with Pixel Precise HD for details in action.
Pixel Precise HD builds on the award winning Pixel Plus foundation. It brings the high definition picture quality to the next level with 4 trillion colours. With Super Resolution, Pixel Precise HD now brings you the best HD TV picture quality whether you are watching a video from the Internet or good quality Blu-ray movies.
Brilliant LED images with incredible contrast.
The most advanced LED lighting technology in this Full HD LED TV combines an eye-catching minimalistic design with stunning image quality as well as the lowest power consumption in its category. On top of that, LED lighting technology does not contain any hazardous materials. Thus, with LED backlights you can enjoy low power consumption, high brightness, incredible contrast, sharpness and vibrant colours.
400 Hz Perfect Motion Rate (PMR) for superb motion sharpness.
400 Hz Perfect Motion Rate (PMR) creates extreme motion sharpness for clear and vibrant images in fast action movies. The new Philips PMR standard shows the combined visible effect of the fastest panel refresh rate, HD Natural Motion and unique processing formula, for unprecedented motion sharpness.
A wealth of online apps, videos to rent and catch-up TV.
Rent films directly on your TV from online video shops, watch catch-up TV from your favourite channels and enjoy a rich selection of online apps with Net TV. You can also browse the open Internet.
With DLNA, enjoy photos, music and movies on your TV.
Share photos, music and movies through DLNA from your smartphone, tablet or computer and enjoy them on the big screen.
Control the TV with your smart phone, tablet or keyboard.
Control your TV in the easiest and most convenient way. Just connect a wireless keyboard or use your smart phone or tablet to control your Smart TV.
Find, schedule, record and pause TV.
Record live digital TV on a USB connected to your Philips TV or pause content whenever you want to take a break and continue watching whenever you want. Use the Electronic Programme Guide to find your favourite programmes and easily schedule your preferred recordings. Now you can programme your TV viewing around your life.
Integrated Wi-Fi to use Net TV apps and SimplyShare wireless.
Enjoy films, pictures, infotainment and other online content directly on your TV wirelessly. Simply connect the TV to your wireless home network with the easy wizard. Navigate the apps using the TV remote control and select from the rich offer of apps.
Full glass, lean back design to fit your living room.
Philips DesignLine Edge TV is beautifully crafted with high quality glass finishing. It appears to float above the table and leans back at an optimum angle of 6 degrees to create the best viewing angle for the living room.
Ambilight Spectra 2 sided intensifies the experience. Easy 3D provides a truly immersive 3D movie experience. -
Full glass, lean back design perfectly fits your living room. -
This full HD TV features Pixel Precise HD for stunning details in action. With brilliant LED images its power consumption is low. 400Hz Perfect Motion rate (PMR) enables superb motion sharpness. -
Control the TV with your smart phone, tablet or keyboard. Enjoy photos, music and movies from any device on your TV. Find, schedule, record & pause TV. Integrated Wi-Fi makes it possible to use Net TV apps and SimplyShare wireless.
- Philips 42PDL7906T - 42" LED-backlit LCD TV
- Product Type
- LED-backlit LCD TV
- 62 Watt
- Diagonal Size
- 42"
- Diagonal Size (cm)
- 107 cm
- Widescreen
- 101 cm x 26.1 cm x 64.5 cm - with stand
- 28.1 kg
- 3D Technology
- Yes ( 3D glasses (2pcs) included )
- Digital Television Certification
- Not certified
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- Input Video Formats
- 1080/24p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Motion Enhancement Technology
- HD Natural Motion, 400 Hz Perfect Motion Rate
- Video Interface
- Component, HDMI, SCART
- HDMI Ports Qty
- 4 port(s)
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Technology
- TFT active matrix
- LCD Backlight Technology
- LED backlight - edge-lit
- Progressive Scan
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T2
- MPEG Decoder
- MPEG-4
- Internet Streaming Services
- Net TV, Smart TV
- Active control, Pixel Precise HD, EasyLink, LightSensor Technology, Eco Mode, Super Resolution Technology (SRT), Ambilight Spectra 2, upgradeable firmware, Wi-Fi CERTIFIED, Pixel Plus link, One touch Play, Remote Control Pass Through, System Standby, Easy 3D
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Sound Effects
- Incredible Surround, Clear Sound
- Supported Flash Memory Cards
- SD Memory Card
- USB Port
- Yes , 2 port(s)
- Remote Control
- Remote control - infrared
- Power
- AC 230V ( 50/60 Hz )
- Series
- DesignLine
- Product Type
- Diagonal Size
- 42"
Display
- Display Format
- 1080p (FullHD)
- Resolution
- 1920 x 1080
- 16:9
- 107 cm
- Widescreen
- 3D Technology
- Video Interface
- HDMI Ports Qty
- 4 port(s)
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Timer Functions
- Sleep
- Dimensions
- With stand
- 101 cm
- 26.1 cm
- 64.5 cm
- 28.1 kg
Display
- Technology
- TFT active matrix
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m2
- Progressive Scan
- Progressive scanning (line doubling)
- Widescreen Modes
- Super Zoom, WideScreen, expand, Autofill, AutoZoom
- Pixel Response Time
- 2 ms
- V-Sync Rate at Max Res.
- 60 Hz
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- MPEG Decoder
- MPEG-4
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM
- Teletext
- Teletext Memory
- 1200 pages
- Electronic Programme Guide
- Digital EPG
- NTSC Playback on PAL TV
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1
- Supported Audio Formats
- MP3, WMA, AAC
- Supported Pictures Formats
- JPG
- SD Memory Card
- USB Port
- Yes , 2 port(s)
Remote Control
Audio System
- Sound Output Mode
- Stereo
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Bass & treble control, Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control
- Speaker(s)
- 2 x right/left channel speaker - built-in - 12 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wireless, wired
- Connectivity Protocols
- IEEE 802.11b (Wi-Fi), IEEE 802.3 (Ethernet)
- Net TV, Smart TV
- DLNA
- Wi-Fi Ready
- Connector Type
- 3 x HDMI ( 19 pin HDMI Type A ) - bottom , 1 x SCART (AV in/out / RGB) ( 21 PIN SCART ) - rear , 1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) - bottom , 1 x audio line-in ( RCA phono x 2 ) - rear , 1 x component video input ( RCA phono x 3 ) - rear , 1 x audio line-in ( mini-phone stereo 3.5 mm ) - bottom , 1 x digital audio output (optical) ( TOS Link ) - bottom , 1 x HDMI ( 19 pin HDMI Type A ) - side , 2 x USB ( 4 PIN USB Type A ) - side , 1 x headphones ( mini-phone stereo 3.5 mm ) - rear , 1 x network ( RJ-45 ) - bottom
- Expansion Slots
- 1 x Common Interface Plus (CI+) slot , 1 x SD Memory Card
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Features
- Swivel
- Flat Panel Mount Interface
- 400 x 400 mm
- Included Accessories
- 2 cleaning cloths
- Power Device
- Power supply
- Nominal Voltage
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 101 cm x 4 cm x 64.5 cm x 19.9 kg , Panel with stand - 101 cm x 26.1 cm x 64.5 cm x 28.1 kg
- Width (Shipping)
- 119 cm
- Depth (Shipping)
- 26.5 cm
- Height (Shipping)
- 74.9 cm
- 5 °C
- 40 °C
- 62 Watt
- Power Consumption Stand by / Sleep
- 0.15 Watt
