Product
Philips 40" BDM4037UW 3840x2160 4K VGA HDMI DP UHD Curved Monitor
Quicklinx: CMD2WS00 Mfr#: BDM4037UW/00
Diagonal Size: 40in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI(MHL), VGA (HD-15)
£457.50 ex VAT
£549.00 inc VAT
Curved display design for a more immersive experience
Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These latest Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or are a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
Ultra Wide-Color wider range of colours for a vivid picture
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
VA display gives awesome images with a wide viewing angle
Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
MultiView 4K for 4 systems on one screen
Philips MultiView feature on this expansive 4K UHD display enables you to have up to four systems each shown in Full HD on one screen. You can use Picture-by-Picture (PbP) to monitor four systems on one screen for control rooms or security. Or for multiple devices like two notebooks side-by-side simultaneously, making collaboration more productive. Or Picture-in-Picture mode (PiP) watching a live football feed from your set-top box, while working on your PC.
SmartImage presets for easy optimised image settings
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
1.074 billion colours for smooth colour gradations and detail
The 10-bit display delivers rich colour depth with 1.074 billion colours and 12-bit internal processing for recreating smooth, natural colours without gradations and colour banding.
MHL technology for enjoying mobile content on a big screen
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
USB 3.0 Hub for convenient access and fast charging
Super Speed USB 3.0 deploys 5.0 gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time to save you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard and allows you to use large capacity storage devices. Now you don't have to wait so long for devices to charge. New FastCharge enables quick charging to charge and go. USB 3.0 is also backward compatible with USB 2.0 devices.
SmartConnect with DisplayPort, HDMI and VGA connections
These Philips displays come equipped with the most advanced multi connections like VGA, Display Port and universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. New DisplayPort and HDMI 2.0 connection now enables full 4K resolution at 60 Hz for smooth visuals. USB connections ensure that you can have super speed data transfers with global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
Slim bezel design for a stylish look
A slim bezel design adds a stylish look to a public display to blend in nicely in just about any environment. Furthermore, this design makes the display ideal for tiled matrix video walls.
  • Slim bezel design for a stylish look
  • Built-in stereo speakers for multimedia
  • SmartImage pre-sets for easy optimised image settings
  • MHL technology for enjoying mobile content on a big screen
  • UltraClear 4K UHD (3840 x 2160) resolution for precision
  • Less eye fatigue with Flicker-Free technology
  • 1.074 billion colours for smooth colour gradations and detail
  • Curved display design for a more immersive experience
  • MultiView 4K for 4 systems on one screen
  • Ultra Wide-Color wider range of colours for a vivid picture
  • VA display gives awesome images with a wide viewing angle
Philips Brilliance BDM4037UW - LED monitor - curved - 4K - 40"
LED-backlit LCD monitor - 40"
Energy Class
Class A
Energy Consumption per Year
89 kWh
Power Consumption (On mode)
61 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.23 mm
Brightness
300 cd/m²
Contrast Ratio
4000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI(MHL), 2xDisplayPort, VGA
Display Position Adjustments
Tilt
Silver, glossy, silver bezel, white (cover)
90.9 cm x 24.7 cm x 64.3 cm
11.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, BSMI, ICES-003, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, MEPS, J-MOSS, KUCAS, CECP, EPA, cETLus, RCM, CU-EAC
Display Type
Energy Class
Class A
89 kWh
61 W
Diagonal Size
40"
Curved Screen
Yes (3000R)
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.23 mm
Pixel Per Inch
110
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, picture by picture, sRGB colour management, MultiView, SmartContrast, SmartImage, Flicker Free technology, 4-screen split, slim bezel design, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, 85% NTSC colour gamut
90.9 cm x 24.7 cm x 64.3 cm - with stand
11.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
VGA , 2 x MHL / HDMI , 2 x DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+10
Flat Panel Mount Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 90.9 cm - depth: 24.7 cm - height: 64.3 cm - weight: 11.6 kg , Without stand - width: 90.9 cm - depth: 7.2 cm - height: 53.2 cm - weight: 11.3 kg
ENERGY STAR Certified
20 - 80%
Philips 40 Bundle deal on Philips 40" BDM4037UW 3840x2160 4K VGA HDMI DP UHD Curved Monitor
£554.49
Diagonal Size: 40in
Response Time: 4ms
Interfaces: HDMI(MHL)
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 300 - 500
