Simplify your connections with USB-C
The Philips E line curved UltraWide display offers expansive panoramic visuals. A WQHD display with an ergonomic stand make for optimal viewing conditions. All-in-one USB-C and MultiView meet the need for productivity.
Connect your notebook with one USB-C cable
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time.
VA display delivers awesome images with wide viewing angles
The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images.
CrystalClear images with UltraWide QHD 3440 x 1440 pixels
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
AMD FreeSync™ Premium; tear free, stutter free, fluid gaming
Gaming shouldn't be a choice between choppy gameplay or broken frames. AMD FreeSync™ Premium equips serious gamers with a fluid, tear-free gameplay experience at peak performance. There are no compromises, game confidently with a high refresh rate, low framerate compensation and low latency.
1 ms (MPRT) fast response for crisp images and smooth gameplay
MPRT (motion picture response time) is a more intuitive way to describe response time, which directly refers to the duration between seeing blurry noise and clean, crisp images. The Philips gaming monitor with 1 ms MPRT effectively eliminates smearing and motion blur and delivers sharper and more precise visuals to enhance your gaming experience. The best choice for playing thrilling and twitch-sensitive games.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Cable management reduces cable clutter for a neat workspace
Cable management is an intimate design that maintains a tidy workspace by organising the cables and wires required for the operation of a display device.
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
Cable management is an intimate design that maintains a tidy workspace by organising the cables and wires required for the operation of a display device. -
LowBlue Mode for easy on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking. -
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time. -
AMD FreeSync Premium; tear free, stutter free, fluid gaming
Gaming shouldn't be a choice between choppy gameplay or broken frames. AMD FreeSync Premium equips serious gamers with a fluid, tear-free gameplay experience at peak performance. There are no compromises, game confidently with a high refresh rate, low framerate compensation and low latency. -
1ms (MPRT) fast response for crisp image and smooth gameplay
MPRT (motion picture response time) is more intuitive way to describe the response time, which directly refers the duration from seeing blurry noise to clean and crisp images. Philips gaming monitor with 1 ms MPRT effectively eliminates smearing and motion blur, delivers shaper and precise visuals to enhance gaming experience. Best choice for playing thrilling and twitch-sensitive games. -
The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images. -
- Philips E-line 346E2CUAE - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/380385
- Energy Class
- Class F
- Energy Consumption per Year
- 57 kWh
- Power Consumption (On mode)
- 31.4 W
- Curved Screen
- USB Hub, USB PD 65 watt
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 at 100 Hz
- Pixel Pitch
- 0.23175 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey), 1 ms (MPRT)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 121.3% sRGB (CIE 1931), 99.5% NTSC (CIE 1976)
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 80.7 cm x 25.7 cm x 49.5 cm
- 10.05 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, ICES-003, CB, TUV Ergo, DDC/CI, RoHS, Lead-Free, EPA, cETLus, CU-EAC, Ukraine, Mercury-free, EAEU RoHS
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 57 kWh
- Diagonal Size
- 34"
- Curved Screen
- Yes (1500R)
- Built-in Devices
- USB Hub
- USB Power Delivery
- 65 watt
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.23175 mm
- Pixel Per Inch
- 110
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 120 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Picture by picture, MultiView, SmartContrast, integrated cable management, SmartImage Game, Mega Infinity Dynamic Contrast Ratio, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, EasyRead, sRGB Mode, Picture-in-Picture
- Textured black
- 80.7 cm x 25.7 cm x 49.5 cm - with stand
- 10.05 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 watt
- HDMI , DisplayPort , USB-C (power up to 65W) , Audio line-out , USB upstream (Type B) , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging)
Mechanical
- Height, tilt
- Tilt Angle
- -5/+20
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), DisplayPort Alt Mode
- Cables Included
- 1 x USB-C to USB-C cable
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 31.4 W
- Power Consumption SDR (On mode)
- 31.4 kWh/1000h
- Power Consumption (Typical)
- 31.81 watt
- Power Consumption Stand by
- 0.5 watt
- 0.3 watt
- Dimensions & Weight Details
- With stand (highest position) - width: 80.7 cm - depth: 25.7 cm - height: 49.5 cm - weight: 10.05 kg , Without stand - width: 80.7 cm - depth: 11 cm - height: 36.7 cm - weight: 7.83 kg
- Shipping Width
- 98 cm
- Shipping Depth
- 22.4 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 13.06 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80%
