Philips 346E2CUAE 34" Monitor
Quicklinx: G2S1WS00 Mfr#: 346E2CUAE/00
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: USB-C, DisplayPort, HDMI
£241.92 ex VAT
£290.30 inc VAT
Simplify your connections with USB-C
The Philips E line curved UltraWide display offers expansive panoramic visuals. A WQHD display with an ergonomic stand make for optimal viewing conditions. All-in-one USB-C and MultiView meet the need for productivity.
Connect your notebook with one USB-C cable
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time.
VA display delivers awesome images with wide viewing angles
The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images.
CrystalClear images with UltraWide QHD 3440 x 1440 pixels
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
AMD FreeSync™ Premium; tear free, stutter free, fluid gaming
Gaming shouldn't be a choice between choppy gameplay or broken frames. AMD FreeSync™ Premium equips serious gamers with a fluid, tear-free gameplay experience at peak performance. There are no compromises, game confidently with a high refresh rate, low framerate compensation and low latency.
1 ms (MPRT) fast response for crisp images and smooth gameplay
MPRT (motion picture response time) is a more intuitive way to describe response time, which directly refers to the duration between seeing blurry noise and clean, crisp images. The Philips gaming monitor with 1 ms MPRT effectively eliminates smearing and motion blur and delivers sharper and more precise visuals to enhance your gaming experience. The best choice for playing thrilling and twitch-sensitive games.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Cable management reduces cable clutter for a neat workspace
Cable management is an intimate design that maintains a tidy workspace by organising the cables and wires required for the operation of a display device.
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Cable management reduces cable clutter for a neat workspace
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • MultiView enables simultaneous dual connection and view
  • Connect your notebook with one USB-C cable
  • AMD FreeSync Premium; tear free, stutter free, fluid gaming
    Gaming shouldn't be a choice between choppy gameplay or broken frames. AMD FreeSync Premium equips serious gamers with a fluid, tear-free gameplay experience at peak performance. There are no compromises, game confidently with a high refresh rate, low framerate compensation and low latency.
  • 1ms (MPRT) fast response for crisp image and smooth gameplay
    MPRT (motion picture response time) is more intuitive way to describe the response time, which directly refers the duration from seeing blurry noise to clean and crisp images. Philips gaming monitor with 1 ms MPRT effectively eliminates smearing and motion blur, delivers shaper and precise visuals to enhance gaming experience. Best choice for playing thrilling and twitch-sensitive games.
  • VA display delivers awesome images with wide viewing angles
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
Philips E-line 346E2CUAE - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/380385
Energy Class
Class F
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
31.4 W
Curved Screen
USB Hub, USB PD 65 watt
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 100 Hz
Pixel Pitch
0.23175 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Colour Support
16.7 million colours
Colour Gamut
121.3% sRGB (CIE 1931), 99.5% NTSC (CIE 1976)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Textured black
80.7 cm x 25.7 cm x 49.5 cm
10.05 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, CB, TUV Ergo, DDC/CI, RoHS, Lead-Free, EPA, cETLus, CU-EAC, Ukraine, Mercury-free, EAEU RoHS
Display Type
Energy Class
Class F
57 kWh
Diagonal Size
34"
Curved Screen
Yes (1500R)
Built-in Devices
USB Hub
USB Power Delivery
65 watt
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.23175 mm
Pixel Per Inch
110
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, MultiView, SmartContrast, integrated cable management, SmartImage Game, Mega Infinity Dynamic Contrast Ratio, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, EasyRead, sRGB Mode, Picture-in-Picture
Textured black
80.7 cm x 25.7 cm x 49.5 cm - with stand
10.05 kg
Audio
Speakers - stereo
Output Power / Channel
5 watt
HDMI , DisplayPort , USB-C (power up to 65W) , Audio line-out , USB upstream (Type B) , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging)
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), DisplayPort Alt Mode
1 x USB-C to USB-C cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31.4 W
31.4 kWh/1000h
Power Consumption (Typical)
31.81 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
Dimensions & Weight Details
With stand (highest position) - width: 80.7 cm - depth: 25.7 cm - height: 49.5 cm - weight: 10.05 kg , Without stand - width: 80.7 cm - depth: 11 cm - height: 36.7 cm - weight: 7.83 kg
Shipping Width
98 cm
Shipping Depth
22.4 cm
Shipping Height
50 cm
Shipping Weight
13.06 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
Diagonal Size: 34in
Response Time: 1ms
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Philips
