Philips 32HFL4014 32" Professional PrimeSuite Commercial LED TV
Quicklinx: FF9BWS00 Mfr#: 32HFL4014/12
TV Tuner Presence: Yes
Video Interface: HDMI
  • DVB-T
Hurry, only 2 left in stock!
£351.29 ex VAT
£421.54 inc VAT
Surprise and delight with a professional IPTV. Cost-effective central management, quick installation, and a customizable UI make this a flexible solution. Philips world-renowned picture quality always engages.
  • UI branding
    Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo and colors to the search bar to increase the visibility of your brand.
  • Built-in pay-to-view solution
    Offer pay-to-view content in any situation-from a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card.
  • IPTV: provide channels over IP
    Provide channels over IP. Install your own user interface (UI), which can be stored on a central server and sent to the TV over IP. Once the UI is on the TV it can also be stored locally. You'll benefit from flexibility and rapid installation whether you're personalizing your Philips Pro System TVs or centralizing system management.
  • CMND & Control
    Run your display network over a local (LAN or RF) connection. CMND & Control allows you to perform vital functions like controlling inputs, updating software, and monitoring display status. Whether you're in charge of one TV or more.
  • CMND & Create
    Take control of your content with CMND & Create. A drag-and-drop interface makes it simple to publish your own content-whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure your stills, text, and video will be up and running in no time.
Philips 32HFL4014 Professional PrimeSuite - 32" LED-backlit LCD TV - HD - for hotel / hospitality
LED-backlit LCD TV
Diagonal Class
32"
Commercial Use
Yes - hotel / hospitality
Resolution
1366 x 768
Display Format
720p
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
Mobile High-Definition Link (MHL)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Internet Streaming Services
YouTube, HbbTV
Commercial Features
VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, IPTV, CMND management, Playready Smoothstreaming, Joystick Control Lock, menu lock
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
2 ports
Philips 22AV1904A/12 remote control, batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class F
Power Consumption (On mode)
28 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
43 kWh
73.2 cm x 7.7 cm x 43.2 cm
4.5 kg
LED-backlit LCD TV
Energy Class
Class F
28 W
28 kWh/1000h
43 kWh
Diagonal Class
32"
Commercial Use
Series
TV Tuner Presence
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Eco mode
Design
Flame retardant cabinet
Dimensions
Without stand
73.2 cm
7.7 cm
43.2 cm
4.5 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Direct-lit LED
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
One touch Play
Stands & Mounts
Stand
Included
Stand Design
Tabletop
VESA Compatibility
TV Tuner
Analogue TV Tuner
PAL
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
MPEG Profiles and Levels
HEVC
Video Features
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC, VP9
Supported Audio Formats
MP3, WMA, WAV, AAC, WMA Pro
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Battery Form Factor
AAA type
Audio System
Digital Audio Format
DTS-HD digital output, Dolby Atmos
Surround Mode
Sound Effects
Incredible Surround
Speaker System
2 speakers
Output Power / Total
16 Watt
Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC)
Speakers
2 x speaker - 8 Watt
Network & Internet Multimedia
Functionality
Internet video playback
LAN
LAN Protocol
Ethernet
YouTube, HbbTV
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
Digital audio output (optical) - rear , LAN - rear , Remote control - rear , HDMI - rear , USB 2.0 - rear , Speakers output - rear , USB 2.0 - side , HDMI - side , Headphones - side
Batteries
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Auto On/Off
WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 73.2 cm x 7.7 cm x 43.2 cm x 4.5 kg , Panel with stand - 73.2 cm x 17.9 cm x 49.4 cm x 4.6 kg
Brand: Philips
