Surprise and delight with a professional IPTV. Cost-effective central management, quick installation, and a customizable UI make this a flexible solution. Philips world-renowned picture quality always engages.
UI branding
Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo and colors to the search bar to increase the visibility of your brand. -
Built-in pay-to-view solution
Offer pay-to-view content in any situation-from a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card. -
IPTV: provide channels over IP
Provide channels over IP. Install your own user interface (UI), which can be stored on a central server and sent to the TV over IP. Once the UI is on the TV it can also be stored locally. You'll benefit from flexibility and rapid installation whether you're personalizing your Philips Pro System TVs or centralizing system management. -
CMND & Control
Run your display network over a local (LAN or RF) connection. CMND & Control allows you to perform vital functions like controlling inputs, updating software, and monitoring display status. Whether you're in charge of one TV or more. -
CMND & Create
Take control of your content with CMND & Create. A drag-and-drop interface makes it simple to publish your own content-whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure your stills, text, and video will be up and running in no time.
- Philips 32HFL4014 Professional PrimeSuite - 32" LED-backlit LCD TV - HD - for hotel / hospitality
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Commercial Use
- Yes - hotel / hospitality
- Black
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL
- Internet Streaming Services
- YouTube, HbbTV
- Commercial Features
- VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, IPTV, CMND management, Playready Smoothstreaming, Joystick Control Lock, menu lock
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- Incredible Surround
- USB
- 2 ports
- Included Accessories
- Philips 22AV1904A/12 remote control, batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class F
- Power Consumption (On mode)
- 28 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 43 kWh
- Dimensions (WxDxH) - without stand
- 73.2 cm x 7.7 cm x 43.2 cm
- 4.5 kg
- Product Type
- Energy Class
- Class F
- 28 W
- Power Consumption SDR (On mode)
- 28 kWh/1000h
- 43 kWh
- Diagonal Class
- 32"
- Commercial Use
- Series
- Professional PrimeSuite
- TV Tuner Presence
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Eco mode
- Design
- Flame retardant cabinet
- Dimensions
- Without stand
- 73.2 cm
- 7.7 cm
- 43.2 cm
- 4.5 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Direct-lit LED
- Brightness
- 250 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- One touch Play
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- VESA Compatibility
TV Tuner
- Analogue TV Tuner
- PAL
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- MHEG
- MPEG Profiles and Levels
- HEVC
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG, Now & Next
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC, VP9
- Supported Audio Formats
- MP3, WMA, WAV, AAC, WMA Pro
- Supported Pictures Formats
- BMP, JPG, GIF, PNG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Battery Form Factor
- AAA type
Audio System
- Digital Audio Format
- DTS-HD digital output, Dolby Atmos
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC)
- Speakers
- 2 x speaker - 8 Watt
Network & Internet Multimedia
- Functionality
- Internet video playback
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- YouTube, HbbTV
- Supported Consumer Electronics Control (CEC)
- EasyLink
- Connector Type
- Digital audio output (optical) - rear , LAN - rear , Remote control - rear , HDMI - rear , USB 2.0 - rear , Speakers output - rear , USB 2.0 - side , HDMI - side , Headphones - side
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
- WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.2 cm x 7.7 cm x 43.2 cm x 4.5 kg , Panel with stand - 73.2 cm x 17.9 cm x 49.4 cm x 4.6 kg
- 0 °C
- 40 °C
