Philips 32BDL4031D 32" 1920x1080 8ms DVI HDMI DisplayPort IPS LED Large Format Display
Quicklinx: FMWTWS00 Mfr#: 32BDL4031D/00
Video Interface: HDMI
TV Tuner Presence: No
  • 1080p
£386.61 ex VAT
£463.93 inc VAT
Make it clear with a powerful Philips D-Line Professional Full HD Display. This responsive solution offers brilliant picture quality, simple control, and reliable connectivity.
  • CMND & Control
    Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • FailOver
    From waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
Philips 32BDL4031D D-Line - 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/394479
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management, FailOver
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
Remote control, batteries
Voltage
AC 120/230 V
Energy Class
Class G
110 Watt
Power Consumption (On mode)
49 W
Power Consumption Stand by
0.5 Watt
72.48 cm x 6.41 cm x 42.43 cm
6.15 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
110 Watt
49 W
49 kWh/1000h
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Series
D-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
Pixel Shift
Dimensions
Without stand
72.48 cm
6.41 cm
42.43 cm
6.15 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Commercial Features
Operation Hours / Days
24 / 7
Picture in picture (no tuner)
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 2 x HDMI input , DVI-I input , Audio line-in , Audio line-out , Remote control , RS-232C input , RS-232C output , Infrared input , Infrared output , DisplayPort output , DVI-I output
Batteries
Serial cable
FCC Class A certified, UL, BSMI, cUL, CB, PSB, EAC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
Limited warranty - 3 years
5 °C
10 - 80% (non-condensing)
Brand: Philips
