Make it clear with a powerful Philips D-Line Professional Full HD Display. This responsive solution offers brilliant picture quality, simple control, and reliable connectivity.
                CMND & ControlRun your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
                FailOverFrom waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
- Philips 32BDL4031D D-Line - 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/394479
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- CMND management, FailOver
- Picture Enhancements
- Pixel Shift
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V
- Energy Class
- Class G
- 110 Watt
- Power Consumption (On mode)
- 49 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 72.48 cm x 6.41 cm x 42.43 cm
- 6.15 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 110 Watt
- 49 W
- Power Consumption SDR (On mode)
- 49 kWh/1000h
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Series
- D-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode
- Pixel Shift
- Dimensions
- Without stand
- 72.48 cm
- 6.41 cm
- 42.43 cm
- 6.15 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 1100:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Operation Hours / Days
- 24 / 7
- Picture in picture (no tuner)
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DisplayPort input , 2 x HDMI input , DVI-I input , Audio line-in , Audio line-out , Remote control , RS-232C input , RS-232C output , Infrared input , Infrared output , DisplayPort output , DVI-I output
- Batteries
- Cables Included
- Serial cable
- FCC Class A certified, UL, BSMI, cUL, CB, PSB, EAC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 0.5 Watt
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 10 - 80% (non-condensing)
