Inform and enthrall with a Philips Q-Line Professional Full HD Display. This reliable solution can be up and running as quickly as you need-with no additional hardware.
CMND & Control
Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100. -
Integrated media player
Easily schedule content to play from USB. Your Philips Professional Display will wake from standby to play the content you want, and then return to standby once playback is done. -
FailOver
From waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
- Philips 32BDL3010Q Q-Line - 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/337802
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/60i, 480/60p, 1080/50i, 720/50p, 576/50p, 1080/60p, 480/60i, 576/50i
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI
- Technology
- VA
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Clinical D-image
- Picture Enhancements
- Dynamic contrast enhancement
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 75 Watt
- Power Consumption (On mode)
- 50 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 72.65 cm x 6.36 cm x 42.54 cm
- 5.2 kg
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 75 Watt
- 50 W
- Power Consumption SDR (On mode)
- 50 kWh/1000h
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Series
- Q-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI
- Modes
- Landscape mode
- Dimensions
- Without stand
- 72.65 cm
- 6.36 cm
- 42.54 cm
- 5.2 kg
Display
- LCD Display Technology
- VA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Clinical D-image
- Operation Hours / Days
- 18 / 7
- 3D MA deinterlacing, DICOM support
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm, 200 x 200 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 720, 720 x 400, 1152 x 870, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
- Supported Video Formats
- Motion-JPEG, H.264, MPEG
- Supported Audio Formats
- WMA, AAC, HE-AAC
- Supported Pictures Formats
- BMP, PNG, JPEG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DVI-I , 2 x HDMI , USB , Audio line-in , Audio line-out , Remote control , RS-232C , Infrared (IrDA)
- Batteries
- Cables Included
- Serial cable , IR sensor cable - 1.8 m
- FCC Class B certified, CB
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Smart power, power on delay
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
