Philips 329P9H 32" 3480x2160 5ms HDMI LED Monitor
Quicklinx: F725WS00 Mfr#: 329P9H/00
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
£709.54 ex VAT
£851.44 inc VAT
When every detail matters, Philips Brilliance 32" 4K display delivers crisp visuals with accurate colour. Convenient features like USB-C docking and a secure pop-up webcam with Windows Hello increase your productivity.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle -- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time.
MultiView enables simultaneous dual connect and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
Securely sign in with pop-up webcam with Windows Hello™
Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello™ facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • UltraClear 4K UHD (3840 x 2160) resolution for precision
  • IPS technology for full colours and wide viewing angles
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Built-in USB-C docking station
  • MultiView enables simultaneous dual connection and view
  • Securely sign in with pop-up webcam with Windows Hello
    Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
  • SmartErgoBase enables user-friendly ergonomic adjustments
  • LowBlue Mode for easy-on-the-eyes productivity
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
  • LightSensor for the perfect brightness with minimal power
Philips P-line 329P9H - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class G
Energy Consumption per Year
80 kWh
Power Consumption (On mode)
51 W
USB Hub, KVM Switch, 2.0 megapixel camera, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.182 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
108% NTSC, 87% Adobe RGB, 90% NTSC (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
71.5 cm x 24.6 cm x 63.6 cm
10.63 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, EPA, cETLus, China RoHS, CU-EAC, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, HDCP 2.2
Display Type
Energy Class
Class G
80 kWh
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.182 mm
Pixel Per Inch
140
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, Sync on Green, Lead-free, PowerSensor, MultiView, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, USB 3.0 Fast Charge, frameless bezel design, LightSensor, EasyRead, sRGB Mode, Picture-in-Picture, Delta E<1 calibration, Windows 10 Hello
Black texture
71.5 cm x 24.6 cm x 63.6 cm - with stand
10.63 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DisplayPort 1.2 , DisplayPort output (HDCP) , 2 x HDMI (HDCP) , USB-C 3.1 Gen 2 upstream (power up to 65W) , 3 x USB 3.1 downstream (Type A) , USB 3.1 downstream (fast charging) , Headphones , Network (RJ-45)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
350
Rotation Angle
180
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable , 1 x USB-C to USB-A cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
51 W
51 kWh/1000h
Power Consumption (Typical)
33 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand - width: 71.5 cm - depth: 24.6 cm - height: 63.6 cm - weight: 10.63 kg , Without stand - width: 71.5 cm - depth: 5.1 cm - height: 41.2 cm - weight: 7.33 kg
Shipping Width
79.3 cm
Shipping Depth
18.6 cm
Shipping Height
67.3 cm
Shipping Weight
14.43 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 32in
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Philips
Price Range Ex VAT: £500 - £750
