This Philips Brilliance monitor with USB-C docking reduces cable clutter. View vivid, crisp 4K UHD images, securely connect to intranet and re-charge your notebook all at the same time with a single USB-C cable.
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time. -
Connect your notebook with one USB-C cable
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time. -
Power and re-charge compatible notebook from the monitor
This monitor features a built-in USB-C connector that meets USB Power Delivery standard. With intelligent and flexible power management, you can now power up and/or re-charge your compatible* Notebook directly from the Monitor using a single USB-C cable. -
High Dynamic Range (HDR) for more lifelike colourful visuals
High Dynamic Range delivers a dramatically different visual experience. With astonishing brightness, incomparable contrast and captivating colour, images come to life with much greater brightness while also featuring much deeper, more nuanced darks. It renders a fuller palette of rich new colours never before seen on a display, giving you a visual experience that engages your senses and inspires emotions. -
Ultra Wide-Color wider range of colours for a vivid picture
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology. -
1.074 billion colours for smooth colour gradations and detail
The 10-bit display delivers rich colour depth with 1.074 billion colours and 12-bit internal processing for recreating smooth, natural colours without gradations and colour banding. -
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive. -
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking. -
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height-adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional. -
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
- Philips Brilliance P-line 328P6VUBREB - LED monitor - 4K - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/398392
- Energy Class
- Class G
- Energy Consumption per Year
- 111 kWh
- Power Consumption (On mode)
- 38.9 W
- USB 3.0 hub, Gigabit Ethernet network adapter
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.181 mm
- Brightness
- 600 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- HDR Capable
- DisplayHDR 600
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% BT.709 (CIE 1976), 116% NTSC (CIE 1976), 138% sRGB (CIE 1931), 98% DCI-P3 (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 74.2 cm x 27 cm x 65.7 cm
- 9.36 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, VCCI, ICES-003, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, PSE Mark, J-MOSS, CECP, EPA, cETLus, RCM, CU-EAC, USB Power Delivery 2.0, DisplayPort 1.4
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 111 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Built-in Devices
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.181 mm
- Pixel Per Inch
- 139.87
- Brightness
- 600 cd/m²
- Contrast Ratio
- HDR Certification
- DisplayHDR 600
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, MultiView, SmartImage, Smart Ergo base, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, PBP, USB 3.0 Fast Charge, USB-C Docking, EasyRead, Ultra Wide-Color Technology, USB-C power delivery up to 60 W, Picture-in-Picture
- Textured black
- 74.2 cm x 27 cm x 65.7 cm - with stand
- 9.36 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- DisplayPort , 2 x HDMI , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery , 4 x USB 3.0 downstream , Audio line-in , Headphones , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 180 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB-C cable , 1 x USB-C to USB-A cable
- MTBF
- 70,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 38.9 W
- Power Consumption SDR (On mode)
- 38.9 kWh/1000h
- Power Consumption HDR (On mode)
- 112 kWh/1000h
- Power Consumption (Typical)
- 41 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- Dimensions & Weight Details
- With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 9.36 kg , Without stand - width: 74.2 cm - depth: 6.3 cm - height: 43.8 cm - weight: 6.4 kg
- Shipping Width
- 97 cm
- Shipping Depth
- 22.4 cm
- Shipping Height
- 52.6 cm
- Shipping Weight
- 13.26 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 80%
