See a new level of detail and clarity with the Philips 28" UltraClear 4K display! Ultra HD, four times clearer than Full HD, colors become richer, details become clearer. Experience Ultra High Definition at an ultra-mainstream price.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
SmartResponse 1 ms refresh for fast gaming
SmartResponse is an exclusive Philips overdrive technology that when turned on, automatically adjusts response times to specific application requirements like gaming and films, which require faster response times in order to produce judder, time-lag and ghost image free images
SmartErgoBase for better ergonomics
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
MHL technology for enjoying mobile content on a big screen
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
HDMI for quick digital connection
Enjoy crisp colourful images and audio with simple one-cable connection. A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality smooth digital video (up to 4K/UHD resolution at 60 Hz) and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
Low bezel-to-table height for maximum reading comfort
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
Calibrated for vivid and true colours
Experience vivid and true colour images. With over one billion colours, your images look exactly as you saw them without visual abnormalities and gradations.
MultiView enables simultaneous dual connect and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
USB 3.0 enables fast data transfers and smart phone charging
Super Speed USB 3.0 deploys a 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard, allowing you to use large-capacity storage devices. Sync-N-Go technology ensures that you no longer have to wait for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backwards compatible.
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain. -
MHL technology
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway. -
USB 3.0 super speed
Super Speed USB 3.0 deploys a 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard, allowing you to use large-capacity storage devices. Sync-N-Go technology ensures that you no longer have to wait for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backwards compatible. -
UltraClear 4K UHD Resolution
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive. -
MultiView technology
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking. -
HDMI ready
Enjoy crisp colourful images and audio with simple one-cable connection. A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality smooth digital video (up to 4K/UHD resolution at 60 Hz) and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
SmartResponse
SmartResponse is an exclusive Philips overdrive technology that when turned on, automatically adjusts response times to specific application requirements like gaming and films, which require faster response times in order to produce judder, time-lag and ghost image free images -
SmartErgoBase
- Philips Brilliance P-line 288P6LJEB - LED monitor - 4K - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class F
- Energy Consumption per Year
- 92 kWh
- Power Consumption (On mode)
- 27.3 W
- USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 65.9 cm x 27.3 cm x 57.3 cm
- 8.04 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, BFR, cETLus
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 92 kWh
- Diagonal Size
- 28"
- Built-in Devices
- USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartResponse, MultiView, SmartImage, Mobile High-Definition Link (MHL), Smart Ergo base, SmartControl Premium, SmartConnect
- Black
- 65.9 cm x 27.3 cm x 57.3 cm - with stand
- 8.04 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- VGA , DVI-D , DisplayPort , HDMI , Headphones , Audio line-in , 2 x USB 2.0 , USB 3.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- 27.3 W
- Power Consumption SDR (On mode)
- 27.3 kWh/1000h
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 65.9 cm - depth: 27.3 cm - height: 57.3 cm - weight: 8.04 kg , Without stand - width: 65.9 cm - depth: 4.9 cm - height: 39.5 cm - weight: 5.24 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £25.26 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
