Philips 277E6LDAD/00 27" 1920x1080 DVI VGA HDMI Monitor
Quicklinx: BYZCWS00 Mfr#: 277E6LDAD/00
Vivid colors, crisp details in an elegant design! Experience brilliant, crisp images like never before with this Full HD, display. With elegant, slim design and SmartImage lite, it looks stunning in every way!
  • HDMI-ready for Full HD entertainment
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • MHL technology for enjoying mobile content on a big screen
    Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
  • SmartContrast for deep black level details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • Modern Touch controls complement the design
    Touch controls are intelligent, touch-sensitive icons that replace protruding buttons to allow users to adjust the monitor to their requirements. Responding to the lightest touch, Touch control gives the monitor a modern feel.
  • 16:9 Full HD display for crisp, detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Philips E-line 277E6LDAD - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
53 kWh
Power Consumption (On mode)
36 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (typical), 1 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Voltage
Glossy cherry black
64 cm x 23.5 cm x 47.8 cm
5.42 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, VCCI, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC
Display Type
Energy Class
Class B
53 kWh
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage Lite, SmartContrast, Touch Control, Mercury free
Glossy cherry black
64 cm x 23.5 cm x 47.8 cm - with stand
5.42 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI-D (HDCP) , MHL / HDMI (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
50,000 hour(s)
Input Voltage
36 W
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 64 cm - depth: 23.5 cm - height: 47.8 cm - weight: 5.42 kg , Without stand - width: 64 cm - depth: 4.8 cm - height: 39.4 cm - weight: 5.17 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
BYZC C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.15
