The Philips Moda 2 combines stunning visuals with the convenience of a Bluetooth speaker system in one refined package. Easily stream your music and take calls from the powerful Bluetooth speaker system, to expand your experience.
AH-IPS technology
AH-IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, AH-IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
Full HD
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors. -
Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
Powerful speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc. depending on model and design. -
SRS WOW HD
Small speakers on most monitors often result in "ho-hum" audio experience. Philips monitors specially tuned with SRS WOW HD, transform your sound experience into an immersive, thrilling event. -
Incredible surround
Incredible Surround Sound technology produces embracing multi-channel surround sound with stereo speakers, without the constrains of room size and the clutter of wires. It delivers an impressive virtual 5.1 sound for immersive movie experience and musical enjoyment. -
Bluetooth streaming
Experience the wireless freedom of Bluetooth technology. Quickly pair your mobile device to the monitor Bluetooth speaker and easily play your favorite music, or even use for hands-free speakerphone calls. -
MHL technology
Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way. -
Super narrow border
Utilizing latest technology panels, these Philips displays are designed with minimalistic approach by limiting the outer bezel thickness to about 2.5 mm. Combined with in-panel black matrix strip of only 3.5 mm, the overall border dimensions are reduced significantly allowing for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow bezel display gives you the feeling of using one large display.
- Philips Brilliance C-line 275C5QHAW - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 24 W
- Microphone
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 14 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy white
- 61.3 cm x 23.8 cm x 46.7 cm
- 5.67 kg
- Environmental Standards
- ENERGY STAR Qualified
- ISO9241-307, Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, CCC, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
- Display Type
- Energy Class
- Class A+
- 34 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, power off timer, sRGB colour management, HDCP, SmartContrast, SmartImage, power on timer, Incredible Surround, SRS WOW HD, Flicker Free technology, Mercury free
- Glossy white
- 61.3 cm x 23.8 cm x 46.7 cm - with stand
- 5.67 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 7 Watt
Input
- Microphone
- VGA , 2 x HDMI , Microphone , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Security lock slot (cable lock sold separately), Stereo Bluetooth Wireless Technology, 360° Flip Design
- MTBF
- 30,000 hour(s)
- Power Supply
- External
- Input Voltage
- 24 W
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Apple MacOS X, Microsoft Windows 7 / Windows 8
- Dimensions & Weight Details
- With stand - width: 61.3 cm - depth: 23.8 cm - height: 46.7 cm - weight: 5.67 kg , Without stand - width: 61.3 cm - depth: 4.2 cm - height: 37.2 cm
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
