Get your best work done with the Philips 27" Quad HD monitor. Crystal-clear Quad HD gives you the space and clarity to see your work. Features like Flicker-free and LowBlue mode make work easy on the eyes.
Built-in stereo speakers
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
LowBlue Mode
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
IPS technology
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
USB 3.0 super speed
Super Speed USB 3.0 deploys a 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard, allowing you to use large-capacity storage devices. Sync-N-Go technology ensures that you no longer have to wait for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backwards compatible. -
CrystalClear images
These Philips screens deliver Crystal Clear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Utilising high-performance panels with high-density pixel count, enabled by high-bandwidth sources like Displayport, HDMI and Dual link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, a user of 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystal Clear images. -
10-bit colours
The 10-bit display delivers rich colour depth with 1.074 billion colours and 12-bit internal processing for recreating smooth, natural colours without gradations and colour banding.
 - Philips B Line 272B8QJEB - LED monitor - 27"
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/420478
- Energy Class
 - Class F
- Energy Consumption per Year
 - 44 kWh
- Power Consumption (On mode)
 - 24.9 W
 - USB Hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
 - 0.233 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 20000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey)
- Colour Support
 - 1.07 billion colours
- Input Connectors
 - HDMI, DVI-D, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Textured black
 - 62.5 cm x 22.4 cm x 53 cm
 - 6.9 kg
- Environmental Standards
 - ENERGY STAR Qualified
 - Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, MEPS, EPA, cETLus, RCM, CU-EAC
- Display Type
- Energy Class
 - Class F
 - 44 kWh
- Diagonal Size
 - 27"
- Built-in Devices
 - USB Hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.233 mm
- Pixel Per Inch
 - 109
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
 - 56 - 76 Hz
- Horizontal Refresh Rate
 - 30 - 83 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - WLED
- OSD Languages
 - Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
 - Sync on Green, sRGB colour management, SmartResponse, SmartContrast, SmartImage, Smart Ergo base, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, EasyRead
 - Textured black
 - 62.5 cm x 22.4 cm x 53 cm - with stand
 - 6.9 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - VGA , DisplayPort , HDMI , 2 x USB 2.0 , Audio line-in , Headphones , DVI-D (dual link) (HDCP) , 2 x USB 3.0
Mechanical
- Tilt Angle
 - -5/+30
- Swivel Angle
 - 350
- Rotation Angle
 - 90
- Height Adjustment
 - 130 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - VGA cable , HDMI cable , DisplayPort cable , Audio cable
- MTBF
 - 70,000 hour(s)
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 24.9 W
- Power Consumption SDR (On mode)
 - 24.9 kWh/1000h
- Power Consumption (Typical)
 - 20.5 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0 Watt
- On / Off Switch
- Included Software
 - Philips SmartControl
- OS Required
 - Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
 - With stand - width: 62.5 cm - depth: 22.4 cm - height: 53 cm - weight: 6.9 kg , Without stand - width: 62.5 cm - depth: 5.1 cm - height: 37 cm - weight: 4.59 kg
- Shipping Width
 - 69.9 cm
- Shipping Depth
 - 24.2 cm
- Shipping Height
 - 45.4 cm
- Shipping Weight
 - 9.96 kg
Sustainability Information
- ENERGY STAR Certified
 - 0 °C
 - 40 °C
 - 20 - 80%
