Get your best work done with the Philips 27" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture. -
SmartImage pre-sets for easy optimised image settings
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button! -
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
Webcam pops up when you need it; secures down when you don't
Webcams are great for connecting with others and collaborating on that important project. Sometimes, though, you don't want a webcam looking down on your desk. Our ingenious new pop-up webcam design pops up when it's time for meetings and for security tucks away nicely when you are not using it. -
USB 3.0 enables fast data transfers and smart phone charging
Super Speed USB 3.0 deploys a 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard, allowing you to use large-capacity storage devices. Sync-N-Go technology ensures that you no longer have to wait for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backwards compatible. -
Designed to meet environmental standards
Designed for sustainability and reduced operating costs, this monitor meets environmental standards. Such as: ENERGY STAR, EPEAT, TCO Certified.
 - Philips B Line 271B8QJKEB - LED monitor - Full HD (1080p) - 27"
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/388112
- Energy Class
 - Class D
- Energy Consumption per Year
 - 34 kWh
- Power Consumption (On mode)
 - 16.7 W
 - USB Hub, 2.0 megapixel camera
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.311 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 20000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 102% NTSC, 128% sRGB
- Input Connectors
 - HDMI, DVI-D, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black
 - 62.5 cm x 22.4 cm x 55.2 cm
 - 6.91 kg
- Environmental Standards
 - ENERGY STAR Qualified
 - FCC Class B certified, TUV GS, BSMI, ICES-003, SEMKO, TUV Ergo, RoHS, Lead-Free, KCC, WEEE, PSE Mark, MEPS, RCM, CU-EAC, BFR-free, Ukraine, PVC-free
- Display Type
- Energy Class
 - Class D
 - 34 kWh
- Diagonal Size
 - 27"
- Built-in Devices
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.311 mm
- Pixel Per Inch
 - 82
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
 - 50 - 76 Hz
- Horizontal Refresh Rate
 - 30 - 83 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - WLED
- OSD Languages
 - Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese
 - Sync on Green, Lead-free, SmartImage, Low Blue Light Mode
 - Black
 - 62.5 cm x 22.4 cm x 55.2 cm - with stand
 - 6.91 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - VGA , DisplayPort , HDMI , Audio line-in , Headphones , DVI-D (HDCP) , USB 3.0 downstream (fast charging) , USB 3.0 downstream , 2 x USB 2.0 downstream , USB upstream (Type B)
Mechanical
- Tilt Angle
 - -5/+20
- Swivel Angle
 - 350
- Rotation Angle
 - 90
- Height Adjustment
 - 130 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable
- MTBF
 - 70,000 hour(s)
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 16.7 W
- Power Consumption SDR (On mode)
 - 16.7 kWh/1000h
- Power Consumption (Typical)
 - 17.4 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- On / Off Switch
- Dimensions & Weight Details
 - With stand - width: 62.5 cm - depth: 22.4 cm - height: 55.2 cm - weight: 6.91 kg , Without stand - width: 62.5 cm - depth: 5.1 cm - height: 37 cm - weight: 4.49 kg
- Shipping Width
 - 69.9 cm
- Shipping Depth
 - 24.2 cm
- Shipping Height
 - 45.4 cm
- Shipping Weight
 - 9.89 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
 - 7.0
 - 0 °C
 - 40 °C
 - 20 - 80%
