Philips 252B9/00 25" 1920x1080 5ms DVI HDMI LED Monitor
Quicklinx: F72FWS00 Mfr#: 252B9/00
Diagonal Size: 25in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15), HDMI
Hurry, only 1 left in stock!
£227.36 ex VAT
£272.83 inc VAT
Expand beyond boundaries with the new 16:10 frameless design Philips B Line monitor. Loaded with features to improve productivity and sustainability, this monitor takes it to the next level.
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
  • Zero power consumption with 0 watt hard switch
    At the flick of the 0 watt hard switch which is conveniently located at the back, you can completely cut-off your monitor from AC power. This results in zero power consumption reducing your carbon footprint even further
  • VESA mount allows for the perfect setup
    VESA pattern guarantees compatibility hundreds of innovative mounting solutions.
  • IPS technology for full colors and wide viewing angles
    IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height-adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional.
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • 100% Recycled packing material
    100% Recycled packing material for less environmental impact.
Philips B Line 252B9 - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/393453
Energy Class
Class E
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
18 W
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.279 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
107.5% sRGB, 90% NTSC (CIE 1976)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, Haze 25%
Voltage
Black texture
54.6 cm x 20.6 cm x 54.1 cm
5.09 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SASO, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2, HDCP 1.4
Display Type
Energy Class
Class E
31 kWh
Diagonal Size
25"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.279 mm
Pixel Per Inch
91
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 96 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Sync on Green, PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, EasyRead, sRGB Mode
Black texture
54.6 cm x 20.6 cm x 54.1 cm - with stand
5.09 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB 3.1 upstream , 3 x USB 3.1 downstream , USB 3.1 downstream (fast charging) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), lead free
1 x VGA cable , 1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 54.6 cm - depth: 20.6 cm - height: 54.1 cm - weight: 5.09 kg , Without stand - width: 54.6 cm - depth: 4.9 cm - height: 36.7 cm - weight: 3.5 kg
Shipping Width
60.8 cm
Shipping Depth
19.7 cm
Shipping Height
52.4 cm
Shipping Weight
7.44 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 25in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: Philips
