Expand beyond boundaries with the new 16:10 frameless design Philips B Line monitor. Loaded with features to improve productivity and sustainability, this monitor takes it to the next level.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life. -
Zero power consumption with 0 watt hard switch
At the flick of the 0 watt hard switch which is conveniently located at the back, you can completely cut-off your monitor from AC power. This results in zero power consumption reducing your carbon footprint even further -
VESA mount allows for the perfect setup
VESA pattern guarantees compatibility hundreds of innovative mounting solutions. -
IPS technology for full colors and wide viewing angles
IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height-adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional. -
LowBlue Mode for easy on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
100% Recycled packing material
100% Recycled packing material for less environmental impact.
 - Philips B Line 252B9 - LED monitor - 25"
 - LED-backlit LCD monitor - 25"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/393453
- Energy Class
 - Class E
- Energy Consumption per Year
 - 31 kWh
- Power Consumption (On mode)
 - 18 W
 - USB 3.1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:10
- Native Resolution
 - WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
 - 0.279 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1 / 50000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 107.5% sRGB, 90% NTSC (CIE 1976)
- Input Connectors
 - HDMI, DVI-D, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, Haze 25%
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black texture
 - 54.6 cm x 20.6 cm x 54.1 cm
 - 5.09 kg
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
 - Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SASO, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2, HDCP 1.4
- Display Type
- Energy Class
 - Class E
 - 31 kWh
- Diagonal Size
 - 25"
- Built-in Devices
 - USB 3.1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:10
- Native Resolution
- Pixel Pitch
 - 0.279 mm
- Pixel Per Inch
 - 91
- Brightness
 - 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
 - 48 - 76 Hz
- Horizontal Refresh Rate
 - 30 - 96 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - WLED
- OSD Languages
 - Multilingual
 - Sync on Green, PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, EasyRead, sRGB Mode
 - Black texture
 - 54.6 cm x 20.6 cm x 54.1 cm - with stand
 - 5.09 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB 3.1 upstream , 3 x USB 3.1 downstream , USB 3.1 downstream (fast charging) , Audio line-in , Headphones
Mechanical
- Tilt Angle
 - -5/+30
- Swivel Angle
 - 350
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), lead free
- Cables Included
 - 1 x VGA cable , 1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
- MTBF
 - 70,000 hour(s)
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 18 W
- Power Consumption SDR (On mode)
 - 18 kWh/1000h
- Power Consumption (Typical)
 - 15 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0 Watt
- On / Off Switch
- Included Software
 - Philips SmartControl
- Dimensions & Weight Details
 - With stand (highest position) - width: 54.6 cm - depth: 20.6 cm - height: 54.1 cm - weight: 5.09 kg , Without stand - width: 54.6 cm - depth: 4.9 cm - height: 36.7 cm - weight: 3.5 kg
- Shipping Width
 - 60.8 cm
- Shipping Depth
 - 19.7 cm
- Shipping Height
 - 52.4 cm
- Shipping Weight
 - 7.44 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
 - 7.0
 - 0 °C
 - 40 °C
 - 20 - 80%
