Philips 24HFL3014 24 Inch HD 16/7 EasySuite Pro TV
Quicklinx: FRYRWS00 Mfr#: 24HFL3014/12
  • DVB-T
Show more with a budget-friendly standalone professional TV. The intuitive CMND solution makes it simple to deploy and manage connected displays. Benefit from simple, fast installation and an on-screen welcome page that's easy to program.
  • CMND&Control
    CMND and Control allows for remote configuration and installation of your TVs from a central location, without the need to visit any rooms. Update and manage all your displays, with minimal effort, all without having to disturb your guests.
  • Built-in pay-to-view solution
    Offer pay-to-view content in any situation from a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card.
  • UI branding
    Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo or custom background to the menu to increase the visibility of your brand.
  • Instant initial USB cloning
    Provides the ability to easily copy all programming and channel programming settings from one TV into other TV sets in less than a minute. The feature ensures uniformity between TV sets and significantly reduces installation time and costs.
  • Mixed channel map
    One integrated channel list for digital and analog channels. This allows the guest to flick seamlessly between Analog and Digital channels.
  • USB auto playback
    Share the fun. Connect your USB memory stick, digital camera, mp3 player or other multimedia device to the USB port on your TV to enjoy photos, videos and music with the easy to use onscreen content browser.
Philips 24HFL3014 24" LED-backlit LCD TV - HD - for healthcare / hospital
LED-backlit LCD TV
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/339397
Diagonal Class
24"
Commercial Use
Yes - healthcare / hospital
Resolution
1366 x 768
Display Format
720p
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, prison mode, mychoice, Double isolation Class II, Multi remote control, CMND management
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
Philips 22AV1903A/12 remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class E
Power Consumption (On mode)
17 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
27 kWh
56 cm x 3.5 cm x 33.6 cm
3.1 kg
LED-backlit LCD TV
Energy Class
Class E
17 W
17 kWh/1000h
27 kWh
Diagonal Class
24"
Commercial Use
TV Tuner Presence
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Eco mode, hotel mode
Design
Flame retardant cabinet
Dimensions
Without stand
56 cm
3.5 cm
33.6 cm
3.1 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Edge-lit LED
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
One touch Play, security lock slot (cable lock sold separately)
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
75 x 75 mm
VESA Compatibility
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
MPEG Profiles and Levels
HEVC
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, TS, AVC, H.264, VC-1, HEVC, MPG
Supported Audio Formats
MP3, WMA, WAV, AAC
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Battery Form Factor
AAA type
Battery Included Qty
2
Battery anti-theft protection
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Incredible Surround
Speaker System
2 speakers
Output Power / Total
6 Watt
Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC), Dynamic Bass Enhancement
Speakers
2 x speaker - 3 Watt
Connector Type
2 x HDMI - rear , Digital audio output (optical) - rear , Audio line-in - rear , VGA input - rear , USB 2.0 - side , Headphones - side
Security Slot Type
Kensington security slot
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
On / Off Switch
Auto On/Off
Dimensions & Weight Details
Panel without stand - 56 cm x 3.5 cm x 33.6 cm x 3.1 kg , Panel with stand - 56 cm x 12.4 cm x 33.6 cm x 3.2 kg
