Philips 243S5LSB/00 23.6" 1920x1080 5ms VGA DVI Monitor
Quicklinx: CJBLWS00 Mfr#: 243S5LSB/00
The Philips LED display using PVC, BFR-free housing is ideal for eco-friendly productivity.
  • SmartContrast for rich black details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • 16:9 Full HD display for crisp, detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Philips S-line 243S5LSB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Textured black, black hairline
55.1 cm x 22 cm x 42 cm
3.66 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, WEEE, cETLus, RCM, ISO9241-307
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Sync on Green, sRGB colour management, HDCP, SmartContrast, Mercury free
55.1 cm x 22 cm x 42 cm - with stand
3.66 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hour(s)
Input Voltage
Power Consumption (Typical)
16.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.1 cm - depth: 22 cm - height: 42 cm - weight: 3.66 kg , Without stand - width: 55.1 cm - depth: 5.2 cm - height: 34.4 cm - weight: 3.22 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
