The Philips LED display using PVC, BFR-free housing is ideal for eco-friendly productivity.
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen. -
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture. -
HDMI ensures universal digital connectivity
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
- Philips S-line 243S5LHMB - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class E
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 17.5 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Black with hairline texture
- 56 cm x 23.2 cm x 52 cm
- 5.12 kg
- Environmental Standards
- TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
- FCC Class B certified, TUV, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus, RCM, Ukraine
- Display Type
- Energy Class
- Class E
- 32 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, SmartResponse, Mercury free
- 56 cm x 23.2 cm x 52 cm - with stand
- 5.12 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , HDMI , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 175
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- VGA cable , HDMI cable , Audio cable
- Input Voltage
- 17.5 W
- Power Consumption SDR (On mode)
- 17.5 kWh/1000h
- Power Consumption (Typical)
- 14.9 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 56 cm - depth: 23.2 cm - height: 52 cm - weight: 5.12 kg , Without stand - width: 56 cm - depth: 5.3 cm - height: 34.8 cm - weight: 3.17 kg
- Shipping Width
- 62 cm
- Shipping Depth
- 19.1 cm
- Shipping Height
- 52 cm
- Shipping Weight
- 7.68 kg
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
