Philips 242S1AE/00 23.8" 1920x1080 4ms VGA DVI-D HDMI IPS FHD Monito
Quicklinx: GR3BWS00 Mfr#: 242S1AE/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15), DVI, DisplayPort
More than 50 In Stock
£117.46 ex VAT
£140.95 inc VAT
Reliable and essential
Philips S Line monitor gives essential features for daily productivity and work comfortably. Virtually frameless with crisp FHD for an extended and clear view. EasyRead and Eye comfort with TUV certified to reduce eye fatigue.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
16:9 Full HD display for crisp, detailed images Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips Low Blue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Smart Ergo Base enables user-friendly ergonomic adjustments
The Smart Ergo Base is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
Smart Image pre-sets for easy optimised image settings
Smart Image is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
EasyRead mode for a paper-like reading experience
  • Effortlessly smooth action with Adaptive-Sync technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artifact-free performance at virtually any framerate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
  • Built-in speakers for audio without desktop clutter
    A pair of stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • Designed to meet environmental standards
    Designed for sustainability, and reduced operating costs, this monitor meets environmental standards. Such as: ENERGY STAR, EPEAT, TCO Certified.
  • SmartErgoBase enables people-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional.
  • IPS technology for full colors and wide viewing angles
    IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • SmartImage presets for easy optimized image settings
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • TUV Eye Comfort certified to reduce eye fatigue
    Philips display meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low blue mode, no disturbing reflections, wide viewing angle and less reduction of image quality from different angles and ergonomic stand designs for ideal viewing experience. Keep your eyes healthy and boost work productivity.
  • 16:9 Full HD display for crisp detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colors expect a true to life picture.
Philips S-line 242S1AE - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405224
Energy Class
Class D
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
107% sRGB, 91% NTSC
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
54 cm x 20.5 cm x 48.2 cm
4.83 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, CCC, TUV Ergo, DDC/CI, RoHS, CECP, CEL, EPA, CU-EAC, TUV Eye Comfort certified
Display Type
Energy Class
Class D
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
107% sRGB, 91% NTSC
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Lead-free, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, SmartControl
Black texture
54 cm x 20.5 cm x 48.2 cm - with stand
4.83 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort 1.2 , HDMI (HDCP) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
14 W
14 kWh/1000h
Power Consumption (Typical)
13.6 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54 cm - depth: 20.5 cm - height: 48.2 cm - weight: 4.83 kg , Without stand - width: 54 cm - depth: 5.1 cm - height: 32.3 cm - weight: 2.98 kg
Shipping Width
62.5 cm
Shipping Depth
18 cm
Shipping Height
43.5 cm
Shipping Weight
7.91 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DVI
Interfaces: DisplayPort
Brand: Philips
