The Philips ergonomic LED display using recycled materials and PVC, BFR free housing is ideal for eco-friendly productivity.
PVC-BFR free housing
This Philips monitor housing is free from brominated flame retardant and polyvinyl chloride. -
SmartPower
SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving. The backlight intensity can be controlled automatically and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs. -
PLS technology
PLS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in 90 degree Pivot mode! Unlike standard TN panels, PLS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
SmartContrast
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
Built-in stereo speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
- Philips S-line 240S4QMB - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23.6 W
- Stereo speakers
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black texture
- 55.5 cm x 22.7 cm x 54.3 cm
- 6.34 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 24"
- Built-in Devices
- Stereo speakers
- Panel Type
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, SmartContrast, SmartImage, SmartPower, Smart Ergo base, BFR/PVC-free, Mercury free
- Black texture
- 55.5 cm x 22.7 cm x 54.3 cm - with stand
- 6.34 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 40,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- 23.6 W
- Power Consumption (Typical)
- 23.59 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 55.5 cm - depth: 22.7 cm - height: 54.3 cm - weight: 6.34 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 4.48 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
