Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it's a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse. -
SmartContrast
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
Mercury Free
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal. -
16:9 Full HD display
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
- Philips V-line 246V5LSB - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.277 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, glossy black
- 56.5 cm x 23.8 cm x 43.5 cm
- 4.65 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
- 2-year warranty
- Display Type
- Diagonal Size
- 24"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.277 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
- Sync on Green, sRGB colour management, HDCP, SmartContrast, 4:3 in Wide
- 56.5 cm x 23.8 cm x 43.5 cm - with stand
- 4.65 kg
- VGA , DVI-D (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20.12 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Philips SmartControl Lite
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 56.5 cm - depth: 23.8 cm - height: 43.5 cm - weight: 4.65 kg , Without stand - width: 56.5 cm - depth: 6.3 cm - height: 35.4 cm - weight: 4.22 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
