Philips 23" LED 1920 x 1080 HD Monitor 16:9 Speakers Black Bezel
Quicklinx: 98YBWS00 Mfr#: S231C3ANW/00
  • Android 4.1 (Jelly Bean)
  • IEEE 802.11n
Open up a new world of opportunities with the Philips Smart All-in-One powered by Android. The expansive 23-inch display is perfect for streaming HD videos, music, eLearning and web surfing to the next level.
  • Smart All-in-One
    Open up a new world of opportunities the Philips Smart All-in-One powered by Android. Now you can enjoy streaming HD video and music, e-Learning, e-books, email and surf the web on its big Full HD screen. Just attach your keyboard and mouse to its built-in USB hub, connect to the web, and you are ready to go. The Google Play app store enables you to download your favorite apps. The VGA and HDMI connectors allow it to be also used as a fully functional computer monitor. With its versatile capabilities, this smart All-in-One can also be used in various business or educational environment.
  • Google Play Store
    Enjoy great applications from the Google Play Store. A single click on the app icon will take you to the store via Wi-Fi or Ethernet connection. Download and install apps for entertainment, games, utilities, office, photos, video, news, social network, etc. The clear, easy-to-use interface helps you to browse intuitively which can be sorted by rating, category or popularity.
  • 16:9 Widescreen Full HD
    The Smart All-in-One features a 16:9 Full HD (1920 x 1080 resolution) screen for a fully immersive entertainment experience. It's fully future-proof as it supports 1080p signals from all sources, including Blu-ray and advanced HD game consoles. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
  • Socialize with webcam
    The integrated webcam, with superb, bright and crisp images, enables you to socialize with your family and friends just like face to face. The Smart All-in-One's ultra-sensitive microphone ensures that your voice carries through crisp and clear. You can hear clear audio either from its built in stereo speakers, or attach your own headphones for private conversation. This simple built-in solution is easy and ready to go at any time.
  • Superb stereo sound
    Immerse yourself with the high quality built-in stereo speakers.
  • Expand your storage
    Accommodate your ever growing library. You can expand your storage capacity by adding external SDHC card or USB flash using the built-in expansion slot.
  • 4 ports USB 2.0 HUB
    A USB Hub allows you to conveniently connect and play multimedia devices such as USB memory devices, camera, portable HDD, web camera, PDA, printer and many other devices. The conveniently located USB 2.0 Hub on the monitor allows USB 2.0 signals to pass thru to the computer for more ease-of-use. Note that many devices like cameras and HDD may need to be powered independently, as they have higher power requirements than the monitor USB Hub can provide.
  • SmartStand
    The Philips Smart All-in-One features a SmartStand with maximum recline adjustability and easy-one-touch-adjustment. The easy adjustment of the SmartStand enables you to use it in various ergonomic positions. With just under 60 degree recline position, you can now interact with the display naturally to touch and type, or you can use it in an upright position to sit and do some serious work.
Philips Smart All-in-one S231C3ANW - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Microphone, USB Hub, 1.0 megapixel camera, 802.11b/g/n network adapter, SDHC card reader
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Response Time
2 ms (gray-to-gray), 5 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Built-in Ethernet
Display Position Adjustments
Tilt
Voltage
Glossy white
56.3 cm x 7.4 cm x 39.3 cm
3.94 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, DDC/CI, RoHS, Lead-Free, WEEE, CECP, CEL, cETLus
Display Type
Diagonal Size
23"
Operating System
Android 4.1
Configuration
Dual core ARM Amlogic 1.5GHz, 1GB DDR3, 8GB EMMC Flash
Supported Multimedia Formats
MPEG-4, H.264, MP3, JPEG, WMV, MPEG-1, MPEG-2, WMA, WAV, OGG, AAC, BMP, PNG, GIF
USB flash drive up to 64GB
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
SmartImage, Mercury free
Glossy white
56.3 cm x 7.4 cm x 39.3 cm - with stand
3.94 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Microphone
VGA (HD-15) , HDMI (Type A) , Network (RJ-45) , 4 x USB 2.0 , Audio line-in (mini-jack) , Headphones (mini-jack) , Microphone (mini-jack)
Mechanical
Tilt
Tilt Angle
+12/+57.5
VESA Mounting Interface
75 x 75 mm
Security lock slot (cable lock sold separately), SmartStand
MTBF
30,000 hour(s)
Input Voltage
Power Consumption (Typical)
12.14 Watt
Power Consumption Stand by
5.15 Watt
Power Consumption Sleep
0.3 Watt
Included Software
E-mail, Google Play, YouTube, Gallery, Music Player
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 56.3 cm - depth: 7.4 cm - height: 39.3 cm - weight: 3.94 kg , Without stand - width: 56.3 cm - depth: 4.7 cm - height: 35.8 cm
Sustainability Information
ENERGY STAR Certified
20 - 80%
