Philips 221S6QUMB/00 22" 1920x1080 USB Monitor
Quicklinx: BYQ0WS00 Mfr#: 221S6QUMB/00
This notebook docking display enables easy port replication. Expand your viewing workspace, keep peripherals connected, access the Internet, all with a single USB cable to your notebook.
  • Expand view with single cable
    This large Philips display enables easy port replication for any notebook. Especially suitable for the ultra-thin notebooks with limited connectors, this display with built-in USB hub, Ethernet and stereo speakers enables you to transmit video, audio and connect to the Internet or intranet directly with a single cable USB connection. Using this advanced USB plug-and-play connection, you can now expand your desktop using both your NBPC and Philips display realestate without having to worry about cumbersome resolution adjustments or messing around with cables.
  • USB hub for peripherals
    You now have the option to connect a full sized keyboard and mouse to the Philips display's USB hub to improve your productivity. Simply connect your Notebook to this display with a single USB cable, and you are ready to utilize the additional peripherals such as the external HDD, camera, USB drive along with Full HD video, Audio and Internet functions. Should you prefer, you can of course still utilize your NBPC's keyboard and track pad as usual.
  • AH-IPS technology
    This Philips display uses advanced AHIPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit the smallest amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With a remarkable performance, it is best suited to applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
  • Flicker-Free technology
    Because of the way brightness is controlled on LED-backlit screens, some users experience flicker on the screen, which causes eye fatigue. Philips Flicker-Free Technology applies an efficient solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Low bezel-to-table height
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
Philips S-line 221S6QUMB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
USB
Speakers
Integrated
Display Position Adjustments
Voltage
Textured black with black stand
51.1 cm x 22.7 cm x 48.3 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, C-Tick, ICES-003, SEMKO, TUV Ergo, PSB, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, E-Standby, KC, CECP, EPA, cETLus, CU-EAC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
sRGB colour management, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
51.1 cm x 22.7 cm x 48.3 cm - with stand
4.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
3 x USB 2.0 , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
150
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
