Philips Flicker Free technology applies an ultimate solution to regulate brightness and reduce flicker for more comfortable viewing. LED allows for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
This LED features the SmartImage - an exclusive advanced Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. The SmartErgo base is a monitor base that delivers ergonomic display comfort and provides cable management. SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving.
Zero mercury content
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal. -
LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button! -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain. -
Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartContrast ratio 20,000,000:1
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight-boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colours. It gives a bright, lifelike picture with high contrast and vibrant colours. -
SmartPower
SmartPower is an artificial intelligent technology which dynamically analyses the content of the screen image to achieve power saving. The backlight intensity can be controlled automatically and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs
- Philips S-line 221S6LCB - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 51.1 cm x 22.7 cm x 48.3 cm
- 4.64 kg
- FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, J-MOSS, E-Standby, CECP, EPA, cETLus, RCM, CU-EAC
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, SmartImage, SmartPower, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
- Textured black
- 51.1 cm x 22.7 cm x 48.3 cm - with stand
- 4.64 kg
- DVI-D (HDCP) , VGA
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 150
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 70,000 hour(s)
- Input Voltage
- Power Consumption (Typical)
- 17.08 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.2 Watt
- Included Software
- Philips SmartControl
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.64 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 2.8 kg
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
