Philips 221B8LHEB 22" 1920x1080 1ms VGA HDMI LED Monitor
Quicklinx: F72QWS00 Mfr#: 221B8LHEB/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
£96.83 ex VAT
£116.19 inc VAT
Get your best work done with the Philips 22" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
  • Zero power consumption
    At the flick of the 0 watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further
  • Built-in stereo speakers
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • HDMI Ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • LowBlue Mode
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Philips B Line 221B8LHEB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Textured black
50.4 cm x 20.6 cm x 47.7 cm
4.45 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, EPA, cETLus, RCM, CU-EAC, BFR-free, Ukraine, PVC-free
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean, Czechoslovakian
Sync on Green, 72% NTSC (CIE 1931) colour gamut, Low Blue Light Mode, Flicker Safe, Mercury free, Adaptive-Sync technology, EasyRead, sRGB Mode
Textured black
50.4 cm x 20.6 cm x 47.7 cm - with stand
4.45 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
VGA cable , HDMI cable , Audio cable
MTBF
70,000 hour(s)
14.2 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
Dimensions & Weight Details
With stand - width: 50.4 cm - depth: 20.6 cm - height: 47.7 cm - weight: 4.45 kg , Without stand - width: 50.4 cm - depth: 4.7 cm - height: 30.4 cm - weight: 2.55 kg
Shipping Width
56.5 cm
Shipping Depth
18.4 cm
Shipping Height
49 cm
Shipping Weight
6.34 kg
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - parts and labour - 2 years
20 - 80%
Philips 221B8LHEB 22 Bundle deal on Philips 221B8LHEB 22" 1920x1080 1ms VGA HDMI LED Monitor
£196.00
Diagonal Size: 22in
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
