Eco-friendly, EPEAT Gold certified Philips Business Line 221B3 LED display with intelligent PowerSensor detects user presence and adjusts power consumption saving up to 80% of energy bills! PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80-percent and prolonging monitor life. Philips' monitor with LED backlighting is free of mercury content, one of the most toxic natural substances which affect humans and animals. This allows for an eco-friendly display throughout its lifecycle, from manufacturing to disposal.
PowerSensor
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80-percent and prolonging monitor life. -
LED technology
White LED is solid state devices which light up to full, consistent brightness faster, saving startup time. LED is free from mercury content which allows for eco-friendly recycling and disposal process. LED allows for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
Mercury free
Philips' monitor with LED backlighting is free of mercury content, one of the most toxic natural substances which affect humans and animals. This allows for an eco-friendly display throughout its lifecycle, from manufacturing to disposal. -
Zero switch
At the touch of a single on/off button which is conveniently located at the back of the monitor, the monitors' energy consumption is reduced to zero. In the off mode, the monitor is completely cut off from AC power and thereby reducing your carbon footprint even further. -
EPEAT Gold
Philips EPEAT Gold certified monitor ensures protection for human health and the environment, and is a highly energy efficient ensuring low emission of climate changing green house gases. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user-friendly interface allows you to select various modes like office, image, entertainment, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The economy mode option offers you major power savings. All in real time with the press of a single button! -
2 ports USB 2.0 hub
USB hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, web camera, PDA, printer and many other devices which have USB connection available. The conveniently located USB 2.0 hub on the monitor allows USB 2.0 signals to pass through to the computer. -
SmartTouch controls
SmartTouch controls are intelligent, touch sensitive icons that replace protruding buttons. Responding to your lightest touch, SmartTouch controls, for example, power up your monitor or brighten and sharpen your display with SmartImage Lite. When activated, SmartTouch icons glow to indicate that your commands have been implemented. -
Height adjustment
The compact ergo base is a 'people-friendly' Philips monitor base that tilts, swivels and is height adjustable so each user can position the monitor for maximum viewing comfort and efficiency.
- Philips Brilliance B-line 221B3LPCS - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured silver
- 50.7 cm x 22.7 cm x 48 cm
- 5.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Built-in Devices
- USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Sync on Green, sRGB colour management, Compact Ergo Base, HDCP, Super Ergo base, PowerSensor, SmartTouch, SmartContrast, SmartImage
- Textured silver
- 50.7 cm x 22.7 cm x 48 cm - with stand
- 5.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D (HDCP) , Headphones , 2 x USB , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 17.8 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- Dimensions & Weight Details
- With stand - width: 50.7 cm - depth: 22.7 cm - height: 48 cm - weight: 5.3 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
