Philips 200V4LAB2 20" 1600x900 5ms VGA DVI Speakers Black Monitor
Quicklinx: BWTBWS00 Mfr#: 200V4LAB2/00
Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with stereo speakers, it's a great choice!
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Powerful sound with 2 x 2 watts RMS speakers
Now you can enjoy all your multimedia and social applications with stereo sound. These built-in speakers not only sound great, but also help you to get rid of external wire clutter and save valuable desktop space.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • Mercury Free eco-friendly display
  • SmartContrast for rich black details
Philips V-line 200V4LAB2 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/387747
Energy Class
Class E
Power Consumption (On mode)
13 W
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2698 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Textured black, glossy black
47.9 cm x 20.1 cm x 36.9 cm
2.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, BSMI, cUL, SEMKO, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EAC, ISO9241-307
Display Type
Energy Class
Class E
Diagonal Size
20"
Viewable Size
19.5"
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2698 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, Mercury free
47.9 cm x 20.1 cm x 36.9 cm - with stand
2.72 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Input Voltage
13 W
13 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS X, Microsoft Windows XP / 7 / 8
Dimensions & Weight Details
With stand - width: 47.9 cm - depth: 20.1 cm - height: 36.9 cm - weight: 2.72 kg , Without stand - width: 47.9 cm - depth: 4.8 cm - height: 29.9 cm - weight: 2.39 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
BWTB C2G 2m HDMI to DVI-D Digital Video Cable In Stock £6.83
