The Philips LED display using PVC, BFR free housing is ideal for eco-friendly productivity.
LED technology
White LEDs are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The economy mode option offers you major power savings. All in real time with the press of a single button! -
SmartContrast
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
SmartPower
SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving. The backlight intensity can be controlled automatically and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs. -
TrueVision
TrueVision is a proprietary Philips technology that uses advanced algorithm for testing and aligning monitor display which gives you the ultimate display performance that is 4 times more stringent than Windows sRGB requirements. Philips ensures each and every monitor that leaves the factory is fine tuned with this process so you can get consistent color and picture quality. -
Zero mercury content
Philips monitors with LED backlighting are free of mercury content, one of the most toxic natural substances which affects humans and animals. This allows for an eco-friendly display through out its life-cycle from manufacturing to disposal.
- Philips S-line 19S4LSB5 - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black with black stand
- 40.4 cm x 19.4 cm x 41.8 cm
- 3.2 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
- Display Type
- Diagonal Size
- 19"
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, SmartContrast, SmartImage, TrueVision, SmartPower
- 40.4 cm x 19.4 cm x 41.8 cm - with stand
- 3.2 kg
- VGA , DVI-D (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 14.3 Watt
- Power Consumption Stand by
- 0.1 Watt
- Included Software
- Philips SmartControl Premium
- OS Required
- Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- Dimensions & Weight Details
- With stand - width: 40.4 cm - depth: 19.4 cm - height: 41.8 cm - weight: 3.2 kg , Without stand - width: 40.4 cm - depth: 6.1 cm - height: 34.6 cm - weight: 2.8 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
