Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it's a great choice!
LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
SmartControl Lite
SmartControl Lite is the 3D icon based GUI monitor control software. This allows user to fine-tune most parameters of the monitor like Color, Brightness, screen calibration, Multimedia, ID management, etc. with the mouse. -
SmartContrast
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
Mercury free
Philips monitor with LED backlighting are free of mercury content, one of the most toxic natural substances which affects humans and animals. This allows for an eco-friendly display through out its lifecycle from manufacturing to disposal. -
ENERGY STAR
ENERGY STAR is a US EPA sponsored energy efficiency program also adopted by many other countries. ENERGY STAR certification ensures that you are buying a product which meets the latest power efficiency standards which operates with maximum power efficiency at all operational levels. For example, in sleep mode ENERGY STAR requires less than 1 W power consumption, whereas Philips monitor consumes less than 0.5 W.
- Philips V-line 196V4LSB2 - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, glossy black
- 44.3 cm x 20.1 cm x 34.9 cm
- 2.98 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, BSMI, GOST, cUL, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
- 3-year warranty
- Display Type
- Diagonal Size
- 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
- Sync on Green, sRGB colour management, SmartContrast, 4:3 in Wide
- 44.3 cm x 20.1 cm x 34.9 cm - with stand
- 2.98 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 14.13 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Philips SmartControl Lite
- OS Required
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7
- Dimensions & Weight Details
- With stand - width: 44.3 cm - depth: 20.1 cm - height: 34.9 cm - weight: 2.98 kg , Without stand - width: 44.3 cm - depth: 4.8 cm - height: 27.9 cm - weight: 2.66 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
