Inform and enthrall with a Philips Q-Line Professional Ultra HD Display. This reliable solution can be up and running as quickly as you need.
Operate, monitor and maintain with CMND and Control
Run your display network over a local (LAN) connection. CMND and Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100. -
FailOver ensures that content is always playing
From waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs, ensuring that content keeps playing even if the primary source goes down. Simply set a list of alternative inputs to be sure your business is always on. -
Schedule what you want, when you want with SmartPlayer
Turn your USB into a true cost-effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on-screen menu, and enjoy your own playlists anytime, anywhere. -
Integrated media player - easily schedule USB content
Easily schedule content to play from USB. Your Philips Professional Display will wake from standby to play the content you want, and then return to standby once playback has finished.
- Philips 43BDL3510Q Q-Line - 43" Class (42.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/394484
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI
- Technology
- ADS
- LCD Backlight Technology
- Direct LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- CMND management, FailOver
- Picture Enhancements
- Motion Compensation, dynamic contrast enhancement, 3D Combfilter
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 150 Watt
- Power Consumption (On mode)
- 100 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 97.3 cm x 6.35 cm x 56.12 cm
- 11.3 kg
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 150 Watt
- 100 W
- Power Consumption SDR (On mode)
- 100 kWh/1000h
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Commercial Use
- Series
- Q-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 97.3 cm
- 6.35 cm
- 56.12 cm
- 11.3 kg
Display
- LCD Display Technology
- ADS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct LED
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- Operation Hours / Days
- 18 / 7
- 3D MA deinterlacing
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 720, 720 x 400, 1152 x 870, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
- Supported Video Formats
- WMV, H.264, MPEG
- Supported Audio Formats
- WMA, AAC, HE-AAC
- Supported Pictures Formats
- BMP, PNG, JPEG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Battery Included
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DVI-I input , 2 x HDMI , 2 x USB 2.0 , Audio line-in , Audio line-out , RS-232C input/output , Infrared input/output , Remote control
- Cables Included
- RS232 cable , IR sensor cable - 1.8 m
- FCC Class A certified, VCCI, BSMI, CB, ETL, EPA, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
